Lenovo Thinkpad L560 No backlight
  • Andreasbest
    • Aug 2014
    • 1178
    • Hellas ( Greece )
    Hello!
    I have a L560 here without backlight on screen, the usual suspect (F1 3A) was burnt so i replace it, 20v are passing through now and arrive to the led backlight flex but still no backlight on screen.
    I tried other lcd but no backlight on them too so the fault is not on lcd.
    There are no schematics available for this board so i'm blind.
    Any thoughts?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo Thinkpad L560 No backlight
    You can refer to any thinkpad schematic with similar pinout.
    • Andreasbest
      • Aug 2014
      • 1178
      • Hellas ( Greece )
      Have you seen a pinout like this?��
      Also one silly question, how is it possible the 20v to arrive at led flex but this to remain off??
      • Andreasbest
        • Aug 2014
        • 1178
        • Hellas ( Greece )
        LA-C422P is quite similar, i see the JEDP1 connector there too and it's identical.
        Any ideas?
        (Page 19 is the lcd connector)
        • mon2
          • Dec 2019
          • 14356
          Tested with a fresh and known good lcd cable?
          • Andreasbest
            • Aug 2014
            • 1178
            • Hellas ( Greece )
            Unfortunately i don't have cable for this model , that's why i want to eliminate all other possibilities before order one.
            What pin should light up the backlight?
            • mielta
              • Apr 2015
              • 368
              mesure pin 7 + 8 bkoff# and invpwm and write how much volt it is
              • Andreasbest
                • Aug 2014
                • 1178
                • Hellas ( Greece )
                No voltage on pin 7 and 8
                Only pins with voltage are 1, 2 & 3 @20V, pin21 @ 3v and pin18 @ 3.3v
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  So your problem is mb related. Voltage on all pins listed by@mielta along with 19V is must for screen display with backlit.
                  • Andreasbest
                    • Aug 2014
                    • 1178
                    • Hellas ( Greece )
                    So what should i check next?
                    • Andreasbest
                      • Aug 2014
                      • 1178
                      • Hellas ( Greece )
                      bump
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        You need to manually trace where those pin7/8 goes. Resistance on both pin7-8?? You can try by cutting the track for pin8 on mb and then applying 3v from dc supply to LVDS connector pin and see if it works.
                        • Andreasbest
                          • Aug 2014
                          • 1178
                          • Hellas ( Greece )
                          The pin 8 goes to a SMD, i'll see if i can desolder it to cut the trace softly and apply 3v
                          • Andreasbest
                            • Aug 2014
                            • 1178
                            • Hellas ( Greece )
                            Should i measure directly @ pin 105 of U34 if the 3v are present?
                            Is this correct?
                            • Andreasbest
                              • Aug 2014
                              • 1178
                              • Hellas ( Greece )
                              Connection between U34 pin 105 and 8pin of JEDP1 is intact.
                              No way to cut the trace as it goes directly on inner layers of MB.
                              Other way?
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                https://www.badcaps.net/forum/showpo...5&postcount=21
                                Edit: Start with the basic checks - the fuses on the screen itself, on both lines 3.3V and 20V, check them first.
                                Become a Badcaps supporter
                                Thanks to all supporters.​
                                • Andreasbest
                                  • Aug 2014
                                  • 1178
                                  • Hellas ( Greece )
                                  Yes battery removed right before the disassembling, these faults are happening only once
                                  The fuses i manage to locate and check are:
                                  F1 (The 20v one, was burnt and replaced the thread with 3A, now 20v passes through it)
                                  F3
                                  F4
                                  F5
                                  F7
                                  F8
                                  PF101
                                  PF201
                                  Is any of them the 3.3v one?
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    Apparently you didn't understand what I meant - I meant that 20V (if the charger is plugged into the laptop) or 12V (or as much as the battery voltage is) is fed/present to the display connector , regardless of whether the machine is running or turned off.
                                    F3
                                    F4
                                    F5
                                    F7
                                    F8
                                    PF101
                                    PF201
                                    I said "the fuses on the screen itself" (screen pcb) - not motherboard fuses. You didn't read carefully. There are usually two fuses, one for 20V and one for 3.3V line.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      Other way?
                                      The other way is to find out the cable connected to pin8 of LVDS pin and cut it and then apply 3v on the part of cable which goes to screen. Anotherway is to find out continuity between pin8 of LVDS and screen connector.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1178
                                        • Hellas ( Greece )
                                        Hello Vesko.
                                        Yes i understand, maybe i didn't type it well.
                                        1) i know the power from PSU and batery are present even if laptop is off in several parts, recently i destroyed a Precision 7510 this way so i got my aftermath.
                                        2) In the previous posts i mention that i have tried several screens, none of them gave backlight (most are broken and/or with lines but backlight used to work), so i guess the voltage from 7 and 8 pin is missing from mb fault, not screens.
                                          Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad X1 Fold Gen 1 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Fold Gen 1 boardview and ThinkPad X1 Fold Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 05:20 AM
                                          Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad T14 Gen 1 (AMD) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad T14 Gen 1 (AMD) boardview and ThinkPad T14 Gen 1 (AMD) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook E Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad E15 Gen 2 (Intel) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad E15 Gen 2 (Intel) boardview and ThinkPad E15 Gen 2 (Intel) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-07-2024, 05:00 AM
                                          Lenovo ThinkPad ThinkPad T15 Gen 2 Notebook T Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad ThinkPad T15 Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad T15 Gen 2 boardview and ThinkPad T15 Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
