hp envy 17m-bw0013dx no LED on charging port
  • kjchatman
    • Dec 2012
    • 213
    • united states
    i'm new to working on boards that aren't for apple laptops and can't seem to find a schematic for this 2018 hp. Its totally dead and the charging port indicator LED doesn't come on but the 19v gets to the current sensing resistor. there is a chip that is gets really warm (tps51285b). I think it's responsible for the LDO voltages.
  • Conste
    • Oct 2018
    • 235
    Re: hp envy 17m-bw0013dx no LED on charging port
    Check resistances in respect to ground of all coils. Could be a bad capacitor.
    • kjchatman
      • Dec 2012
      • 213
      • united states
      anyone have a schematic for this model?
      • reformatt
        • Feb 2020
        • 1533
        Very few schematics available for the newer models unfortunately. But they usually fall in the same basic design so you can do some limited troubleshooting.
        As you said, the +3.3V/5V IC is getting warm so have a look at the LDO output voltages. They are simple linear regulators with limited output current. If the voltage is low, it's usually not the IC but the load on that output. Sometimes you can get lucky and its just a shorted bypass cap, but can also be the EC itself.
        • kjchatman
          • Dec 2012
          • 213
          • united states
          i'm not really good at finding a fault without a schematic. the VIN of the chip is only 9v and that should be 19v i'm assuming. in fact 9v is what's i'm measuring all over the board
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            9V as VIN is very likely correct as NVDC technology is perhaps in use in charging circuit. resistance on +3V LDO/+5V LDO?? Measure resistance without any power connected.
            • reformatt
              • Feb 2020
              • 1533
              Use the datasheets for the IC's. Most of the time, the circuits in the laptops mirror what's in the datasheet. Except for Dell's.....
              • niggi
                • May 2016
                • 209
                • UAE
                hp envy 17m-bw0013dx need Bios
                • mon2
                  • 14713
                  @niggi - bios requests are in another part of this forum. See above.
                  • munir100
                    • Dec 2018
                    • 188
                    • uae
                    HP Envy m laptop model 17m-bw0013dx sn=5CG8258XXF Problem is no dispaly i try to me clean but still same hare is bios file Haymitch 2G MB 17888-1
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Do not attach and/or request bios files here at main Tech section please!
                      Read Reminder: rules and organization of this section thread, and posting rules in BIOS Requests ONLY! sub-section:
                      https://www.badcaps.net/forum/troubl...before-posting​
                      Become a Badcaps supporter
                      Thanks to all supporters.​
                      • REpairAT
                        • Nov 2020
                        • 151
                        • Austria
                        Hi, any solution? Got the exact same issue. There's absolutely no measurable short on the board, no powerline, no mosfet, no cap, nothing.
                        Owner told, he wasn't able to turn it off anymore. As soon as he took out the battery, it never turned on again, if this is some hint.
                        Injecting 3.3V into VREG3 takes 1mA what looks good, but injecting 5V into VREG5 shows 25mA what looks high to me, for a machine that's turned off.
                        Any ideas?
                        Thanks a lot!
                        PS my board is Haymitch 4G MB 17889-1 448.0EJ11.0011 what seems to be the same, just 4GB VRAM.
                        • drnict61
                          Nic’s Fix
                          • Dec 2020
                          • 7
                          Has anyone with the same symptoms taken the board out and looked at the other side??
                          There is a shorted cap c6701.
                          Unsure what it's values could be, but I will try to trace it to the nearest connected IC and look up a datasheet to hopefully identify a suitable replacement value
                          cheers​
