Veocam 2 21022 help identifying charging port please
  • paulyboy
    • Mar 2020
    • 130
    • New Zealand
    I have been given a device to fix it sustained a drop resulting in two inductors ripping of aswell as the charging port along with many traces. I was hoping i could wire up a USB C breakout port as I could not find the correct port replacement online and customer needs urgently, could some help identify the pinnout it would be appreciated.
    • Jul 2011
    • 6037
    Take a picture of the other side of the board and also a picture of usb port as well
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
    • Scarfycake
      ASUS proart Studiobook h7600ZW; Had DC in port replaced and all the sudden it isn't charging but is the charging sign is on!
      by Scarfycake
      I sent my ProArt Studiobook 16 OLED (H7600, 12th Gen Intel) to the local repair guys to have a very simple DC in port replaced. I sourced the part myself on accessoires-asus (french company) after struggling to find the right part in the UK. It looked completely the same to the installed part from what I can tell. Originally the only issue with the laptop was a bad / loose DC connection, and so the computer and battery acted completely normal aside from a very poor connection that would fail at certain angles. After the repair was completed I brought it home and used it for...
      05-21-2024, 08:16 AM
    • paparazzo79
      USB type C as charging port on laptops
      by paparazzo79
      Hi guys.
      I wanted to purchase HP Elite x2 1012 G2 laptop but I saw that the charging port is type C and I remember Mr.Sorin from electronicsrepair on yt telling that the worse charging port for laptops is type C and on other channels I saw that they mostly fail especially HP Spectre X360, so I assume I should avoid laptops with type C charging port (dunno why) or it just depends on model?
      He mentioned that laptop fail because of that port,and simply become dead,and most of the models fail because of that port.
      01-25-2023, 09:12 AM
    • Thomasraud
      Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
      by Thomasraud
      i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
      QUOTED
      -It works on charger (without battery connected-only charger)
      -It works on battery (without charger connected-only battery)
      -& it also works when plugged in battery & charger, but it's not charging the battery
      //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
      and..
      QUOTE
      The IC cannot maintain the input current level
      06-28-2022, 06:47 PM
    • sofles
      Bowers & Wilkins PX7 S2 Needed help with identifying charging IC
      by sofles
      Hi there,
      Recently I bought broken Bowers & Wilkins PX7 S2, the problem with them is that battery discharges on its own even with headphones turned off. It is a quite common issue with this model and even with model higher PX8.
      With help of thermal camera I found out that there is one IC that is hot even with headphones turned off. To check if I'm correct I bought another PX7 S2 working one and replaced small charging board with this IC and problem solved, battery no more drains on its own. After changing board back to original problem returned so I'm 100% sure problem...
      05-30-2025, 01:11 PM
