Lenovo 330-15ICH battery problem
  • AntraX0601
    • Feb 2020
    • 12
    • Czech Republic
    Hello, i have problem with my laptop, anywhere if i has of 45 percent battery my laptop goes sleep an after plug charger it shows 0 percent. I replace the battery for new and original and the same problem. Sometimes it goes off at 55 percent or around this.
    What is bad? Are the second battery bad or something in motherboard?
    Thanks.
  • mon2
    • 14334
    Re: Lenovo 330-15ICH battery problem
    Hi.
    Was the battery purchased from a reliable source? The details seem to hint there is something is wrong with the logic board.
    Post the full markings on the batteries. Maybe the batteries are not compatible with this unit ?
    Did the original battery ever work with this computer?
    What is the history? Any liquid damage?
    Do you have test equipment like tools, soldering iron, multimeter?
    • AntraX0601
      • Feb 2020
      • 12
      • Czech Republic
      I dont know if the battery ever works with computer. I bought the laptop with the water damage. I only replace the keyboard and all works fine. But battery has this defect, i think its bad battery.
      I repairing laptops, but i am beginner. Maybe i think its defect from "logical"(charging) chip for battery on motherboard?
      I have no problem with replace the chip, but i dont know if its that problem.
      Sorry for english iam czech.
      • AntraX0601
        • Feb 2020
        • 12
        • Czech Republic
        And battery is from Aliexpress, but they say its original and looks at original.
          • 21182
          Are you using Lenovo Energy Management software,if you are check the settings. Have you checked the battery with Lenovo Diagnostics
          • piernov
            • Jan 2016
            • 4437
            • France
            "original", "new" and "Aliexpress" never go together very well.
            • AntraX0601
              • Feb 2020
              • 12
              • Czech Republic
              Lenovo energy manager shows the battery is in good condition.
              Calibrate battery with energy manager goes well from 100 to 0%.
              Any idea? Before i bought new battery?
              • NConstantinou
                LENOVO YOGA 7 14ITLS 15 BATTERY REPLACEMENT PROBLEM
                by NConstantinou
                Dear all,
                i have the above laptop which had a problem with battery. i replaced it with a compatible one..
                the laptop DOES NOT POWER ON..
                with it old battery it does power on.
                i left the new battery disconnected and i powered on the laptop and i reconnected battery while laptop was on. it shows that the battery is charging.
                when i shutdown the laptop does not power on.
                does anyone have any solution!
                when is not power on the usb c voltage tester shows 5v 1.3A
                when i disconnect battery and power on and then connect battery the tester...
                12-10-2024, 04:52 AM
              • GabrielS24
                Lenovo E540 battery problem
                by GabrielS24
                Hello! I'm here to look for solutions to reset the EEPROM memory of a Lenovo E540 battery of 62Wh and 540mAh. I even bought a new one on the market (aftermarket BTIBM30) because I couldn't find an original one but it doesn't work. The laptop sees the percentage but blocks the battery charging probably because of the Chinese BMS. In the bios I don't have an option for the battery and I didn't find an older version (v1.57). I replaced the Lenovo BMS with Chinese cells but in windows it doesn't read the battery percentage and says it needs to be changed. I have 12v between D and the red wire....
                04-16-2025, 05:23 AM
              • code share
                Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                by code share
                I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                Here's what I've tried so far:
                • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                • Booted successfully on AC power only with the battery disconnected
                • Visual inspection of the battery — no swelling, burn marks, or connector damage
                • Battery
                04-21-2025, 12:50 PM
              • NConstantinou
                LENOVO GYG41/GYG51 NM-D131 REV:1.0 BATTERY PROBLEM
                by NConstantinou
                Dear all
                i have the above laptop which had problem with charging and was repaired. the laptop battery need to be replace also and i did but laptop did not power on with new battery.
                installing old battery back, power comes on.
                i noticed on battery connector instead of 3.3v on pins 3 and 4, i get 2.9-3.3v and is flactuating.
                can someone help!!!
                11-26-2024, 06:08 AM
              • mrkmpn
                Lenovo Yoga C930-13IKB EYG70 NM-B741 Battery not detected.
                by mrkmpn
                Hello, I have a customer that brought this laptop in after replacing his battery. He said his original battery charge was not lasting long, and after replacing the battery with one purchased from iFixit, the charging worked for about 30 minutes and then stopped, and the battery is no longer detected by windows.
                This laptop powers on when the AC adapter is connected, and my USB-C multimeter shows current being used with both ports, but the charging light does not come on, and in Windows the battery icon shows an X as if there is no battery present. If I disconnect the AC adapter,...
                03-13-2024, 01:54 PM
