LA-H331P freezes with power, BSOD with batteryf
  • rookieme
    • Oct 2014
    • 396
    • Greece
    Ok, this is a XPS 15 7590 that it just freezes in seconds when you plug in the power even at bios menu
    With battery only you can get it to work at bios but when you try to boot at OS or try to boot from windows usb boot you get errors like driver overrun, security check failure, page fault in nonpaged area and many others.
    So far ram swapping has been tested and bios update has been performed.
    Could it be an issue at a buck converter that fails with 19V and doesn't work properly with battery either?
    Thank you in advance
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: LA-H331P freezes with power, BSOD with batteryf
    Try changing caps connected with cpu core lines.
    • rookieme
      • Oct 2014
      • 396
      • Greece
      Thank you fro the reply,
      the CPU has 2 main caps at the side at 470uf and one slim at the bottom at 200uf.
      I measured the first two at 500 & 480uf.
      Instead of replacing them as I only have 330uf I made a bridge and added one 330 at the side of each 470uf.
      The test have me the same results, no display with power, BSOD with battery.
      One more thing I forgot to mention is that heatsink becomes too hot to touch - it conducts heat properly and fan spin as they should.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        As you are aware, you cant replace cap with lower value-higher vale will do
        • rookieme
          • Oct 2014
          • 396
          • Greece
          yes, I didn't replaced them but I added 2 more in parallel to maximize the capacitance
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • meraklinetx
            Asus Z97-a power cycle, no boot no cpu voltage
            by meraklinetx
            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
            05-10-2023, 06:08 AM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
            03-31-2024, 02:12 PM
          • joaquinmjuan
            Canon TS8350 Screen Freezes on Power On
            by joaquinmjuan
            Hello, I have a Canon TS8350 printer. The problem is that when I turn it on, "CANON" appears on the screen, but it never goes away. You can leave it on for a whole day, and it doesn't go away. Does anyone know how to fix this? I've tried unplugging it, but nothing. I've also tried holding down POWER, but nothing. In fact, once it turns on, it can't be turned off with the Power button. I've also held down Power and then plugged it into the Power supply, and the power light flashes once and doesn't turn on, but then when I press Power again, it turns on. Currently, it's a nearly new paperweight,...
            05-07-2025, 12:26 AM
