I'm trying to write a ENE KBC on a HP 15-R212NL, the problem is after I connect everything to the programmer and when I press read it says that I need to update firmware programmer and I don't know how to fix it...
Vertyanov Ver 4.C
Re: Vertyanov Ver 4.C
Its not a Vertyanov its a clone.Lots of members here have one, i don`t know how they go about updating the firmware because if its updated with the real vertyanov firmware it can brick it https://www.badcaps.net/forum/showthread.php?t=77094 .Contact SAS support,there might be a manual firmware update for it ? -
Thank you very much about the information, I'll contact them. Have a good day!Its not a Vertyanov its a clone.Lots of members here have one, i don`t know how they go about updating the firmware because if its updated with the real vertyanov firmware it can brick it https://www.badcaps.net/forum/showthread.php?t=77094 .Contact SAS support,there might be a manual firmware update for it ?Comment
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
...Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by rumpumpel1Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?10-24-2024, 08:59 AM
by dkneyleDiagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about... -
by piernovInfineon TPM firmware update files:
Infineon_firmware_update.zip
...Code:TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
Channel: BIOS Requests ONLY!
10-25-2025, 10:09 AM -
- Loading...
