Asus N750JK not charging and not turn on.
  • whipeer
    • Jan 2019
    • 3
    • hungary
    Hello!
    I have a Asus N75JK But its not charging and not turning on.
    BUT!
    I take off the first mosfet and tie it up, then it turns on, but not charging.
    I replace the charge controller ic.
    The mosfet is not short-circuited.
    • 21896
    Re: Asus N750JK not charging and not turn on.
    What do you mean by tie it up. Whats the motherboard version
    • mon2
      • Dec 2019
      • 14666
      Hi.
      1) which charger IC is onboard. Full markings.
      2) post the voltages on each pin of the charger IC.
      3) you may have another damaged mosfet. Remove all power. Meter in resistance mode (2k scale).
      Measure and post the resistance between:
      Source (1-2-3) and drain (5-6-7-8)
      Source (1-2-3) and gate (4)
      Gate (4) and drain (5-6-7-8)
      For each mosfet.
      • piernov
        • Jan 2016
        • 4439
        • France
        https://www.badcaps.net/forum/showthread.php?t=90356
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
        • MicroSMD Lab
          ASUS ROG Zephyrus GPU Mosfet repeat failure
          by MicroSMD Lab
          The board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • someonenotyou
          ASUS G513R - cannot remove MOSFET
          by someonenotyou
          Hi.
          I have a ASUS G513R laptop with shorted MOSFET (MP86959GMW-Z 45A).
          I tried to preheat the board to 200C brom the bottom and with rework station set to 400C I flowed it for about 2min. The MOSFET does not come off.
          Of course, I did not force it, but tried to lift it up with tweezers.
          Is it possible, that these MOSFETs are glues to the board? Or it got welded to the board from the short? It looks intact, no signs of blowing up.
          10-10-2025, 11:05 AM
        • coasterghost
          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
          by coasterghost
          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
          System Hardware:
          Processor: AMD Ryzen 7 PRO 5850U
          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
          09-08-2025, 10:46 PM
