Asus N750JK not charging and not turn on.
  • whipeer
    • Jan 2019
    • hungary
    Hello!
    I have a Asus N75JK But its not charging and not turning on.
    BUT!
    I take off the first mosfet and tie it up, then it turns on, but not charging.
    I replace the charge controller ic.
    The mosfet is not short-circuited.
    • 21186
    Re: Asus N750JK not charging and not turn on.
    What do you mean by tie it up. Whats the motherboard version
    • mon2
      • 14342
      Hi.
      1) which charger IC is onboard. Full markings.
      2) post the voltages on each pin of the charger IC.
      3) you may have another damaged mosfet. Remove all power. Meter in resistance mode (2k scale).
      Measure and post the resistance between:
      Source (1-2-3) and drain (5-6-7-8)
      Source (1-2-3) and gate (4)
      Gate (4) and drain (5-6-7-8)
      For each mosfet.
      • piernov
        • Jan 2016
        • 4437
        • France
        https://www.badcaps.net/forum/showthread.php?t=90356
        • flat-earther
          ASUS X54H laptop thinks it's always charging even with charger unplugged
          by flat-earther
          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
          Windows also shows ''Plugged in'' when charger is not connected.
          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
          If I let battery run out and say it has 3% Windows will...
          06-24-2025, 09:32 AM
        • Scotchmist
          Asus GA502D keeps blowing mosfet
          by Scotchmist
          I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
          I have removed the mosfet and can run the laptop no problem
          The MOSFET is FDPC5018SG
          Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
          08-24-2024, 02:23 PM
        • MicroSMD Lab
          by MicroSMD Lab
          I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
          01-10-2024, 06:36 AM
        • Timp74
          Odd MOSFET only on some ASUS x99/x299/z370 motherboards..
          by Timp74
          Hi All,
          Could anyone comment on the purpose of the MOSFET circled in red in the attached photo of an ASUS ROG X299 Extreme VRM?
          I'm trying to fix an ASUS motherboard(WS x299 SAGE) with a similar VRM where this MOSFET has burnt out along with one of the IR3555m driver chips. From looking at photos of motherboard VRMs on the internet, it seems only some ASUS motherboards have a MOSFET like this. Although I've seen some photos of ASUS z370 boards where it's not populated. The MOSFET is usually a NTMFS4C06N. It has its drain connected to the output of the Vcore VRM, and on...
          08-13-2021, 01:11 PM
        • thomasmagic
          not charging asus g531gw 1.6
          by thomasmagic
          hello,
          if you can help me, i have mainboard asus g531gw Rev 1.6 with short and no power
          i have found short on C3907 (PVDD_AMP) and remove it
          Actually machine works but battery is not charging. I have test with new one and i have too replace BQ24780S (charging IC) and same problem.
          It's not 1st time when i remove short after the battery is not detect
          On mybook i know we can make jumper beetween two lines for recognised this one
          do you have solution for pc and actually this mainboard? Thanks for your help ...
          06-19-2025, 12:54 PM
