Macbook 820-01700 Stuck at 5V
  • powerblackout
    • Feb 2018
    • 109
    Can't get my 820-01700 to boot. ammeter says 5v and 0.05 amps. Board is a few years old, has no signs of corrosion at all.
    I went through the power rails and measured them:
    PPBUS_G3H - 12.3v
    PPBUS_HS_CPU - 12.3v
    PPBUS_HS_GPU - 12.3v
    PPBUS_HS_OTH5V - 12.3v
    PPBUS_HS_3V3G3H_T - 12.3v
    PP3V3_UPC_XA_LDO - 3.38v
    PP3V3_G3H_T - 3.37v
    PP3V3_G3H_RTC_X - 3.38v
    P3V3MAIN_PGOOD - 3.3v
    PP1V8_SLPS2R - 1.86v
    PP0V8_SLPS2R - 0.797v
    PP1V1_SLPS2R - 1.1v
    PMU_ONOFF_L - 3.37v
    PMU_RSLOC_RST_L - 3.38v
    PP1V2_AWAKE - 1.19v
    PM_SLP_S4_L - 0v - 98k resistance to ground
    PP5V_S5_LDO - 0.0v - 3.8k resistance to ground
    PP5V_G3S - 0.0v - 260 ohm resistance to ground
    P5VG3S_PGOOD - 0v - 69k resistance to ground
    PP1V8_G3S - 0.0v - 211 ohm resistance to ground
    Behavior and measurements are the same for all 4 usb ports.
    Any ideas on where I need to look? The apple store wants $800 to replace the board. I'm trying to learn so I can do it cheaper.
  • powerblackout
    • Feb 2018
    • 109
    Re: Macbook 820-01700 Stuck at 5V
    When I plug the motherboard into another macbook to do a DFU restore it immediately shows up on the other machine as DFU. When I tried to do a revive I get an error about expecting recovery mode.
    When I start the revive the board goes to 20V 0.01A then I get an error
    "Unexpected device state 'DFU' expected 'Recovery' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)]"
    • mon2
      • Dec 2019
      • 14156
      No personal experience with this but @Piernov noted that T2 bridgeOS must be there for the 20V power delivery contract to work on this logic board. So your approach is logical.
      See here:
      https://boards.rossmanngroup.com/thr...roblems.61662/
      also T2 based.
      • powerblackout
        • Feb 2018
        • 109
        Thanks, after giving that a read my 0V9_SSD is 0.00v, and has a 0.342 diode reading. It goes into DFU mode without having to press any keys, it happens when the board is outside the case disconnected completely. Is there something on the board that can do that?
        My AWAKE and SLPS all look fine I think:
        PP1V8_AWAKE - 1.8v
        PP1V2_AWAKE - 1.19v
        PPVDDCPUSRAM_AWAKE - 0.8v
        PPVDDCPU_AWAKE - 0.756v
        PP3V3_AWAKE - 3.37v
        PP1V1_SLPS2R - 1.1v
        PP1V25_SLPS2R_SMC_AVREF - 1.25v
        • powerblackout
          • Feb 2018
          • 109
          After more researching it appears U9500 controls U9580 via the SSD0_VR_P2V5_EN which on this board is always 0v, would this mean the U9500 is having issues?
          • mon2
            • Dec 2019
            • 14156
            Yes, it may be. Confirm the presence and voltage of PP3V3_G3H_SSD0_SNS.
            • powerblackout
              • Feb 2018
              • 109
              PP3V3_G3H_SSD0_SNS is present, 3.38v.
              I didn't realize there was another set of these for SSD1, I checked these two
              SSD1_VR_P2V5_EN - 0.0v
              PP3V3_G3H_SSD1_SNS - 3.38v
              What are the chances that both U9500 and U9000 are broken? Or maybe I need to look further upstream for something that controls both of these?
              • powerblackout
                • Feb 2018
                • 109
                Is it normal that the macbook immediately shows up in apple configurator 2 as soon as i plug it in? i don't have to do the keyboard shortcuts.
                If I plug the charger in, then start the revive process, the charger will jump to 20V 0.01A, but PPBUS_G3H will still be 12.3V
                • mon2
                  • Dec 2019
                  • 14156
                  Not familiar with the Configurator 2 tool so wait on others to comment.
                  This is correct that the power delivery contract with 20V is ultimately selected by the ACE controller and the PPBUS_G3H steps this voltage down to 12v3. Thought I read on Logiwiki that 12v6 is the sweet spot after some more states are enabled on the power rails. Either way, you are very close on the PPBUS_G3H rail.
                  reference:
                  https://logi.wiki/index.php/PPBus_G3H
                  • powerblackout
                    • Feb 2018
                    • 109
                    https://apps.apple.com/us/app/apple-...37126344?mt=12 the app that allows DFU revive/restore?
                    • powerblackout
                      • Feb 2018
                      • 109
                      Do you know what controls the creation of the 0.9, 1.8, 2.5v from this chip? I checked SSD_PMU_RESET_L (1.8v), is it controlled via the SCL/SDA communication?
                      • powerblackout
                        • Feb 2018
                        • 109
                        Another discovery. I hooked my oscilloscope up to I2C_PWR_SDA and I2C_PWR_SCL lines going to the charger, i see them go up to 1.785v but they do not have any traffic on them. I see i2c is controlled by T2 chip, this would suggest why battery isn't charging and why U9500 isn't turning SSD on? because T2 is messed up and not communicating over i2c?
                        Another discovery! I put the ammeter between the two machines, when the revive process starts the ammeter reads 4.93v 0.2a, and the T2 chip gets to about 80 F while the rest of the board is at 70 F. While it is doing this the PP2V5_NAND_SSD0 etc are still 0
                        • powerblackout
                          • Feb 2018
                          • 109
                          I got it up to 4.46V 1.03A using a beefier usb cable. it appears it is charging the battery from the other macbook, I see the PPBUS_G3H voltage rising and I see i2c traffic on the ribbon going to the battery. This all only happens once a revive is started.
                          The DFU revive failed with error code 4005, I finally found a site that had some information on what that means https://logi.wiki/index.php/DFU_Mode_Restore_(Macs)
                          4005 = SSD not found.
                          So if T2 chip is actually starting to be revived, but can't find SSD for the T2 partition, and i2c appears to be functioning, where else should I look to find why it can't turn SSD on? Why U9500 Why!
                          • mon2
                            • Dec 2019
                            • 14156
                            U3900 (SMC) is the I2C bus master and the voltage readings for I2C_PWR_SCL and I2C_PWR_SDA look good.
                            This voltage sounds low. Personally have not yet used the configurator 2 tool but working on some T2 logic boards now so may have this need.
                            SSD_PMU_RESET_L is driven by U3900, J32 ball (marked as OUTPUT).
                            Meter in resistance mode, remove all power. What is the resistance to ground for PP2V5_NAND_SSD0 ?
                            • powerblackout
                              • Feb 2018
                              • 109
                              Measured SSD_PMU_RESET_L it is 1.8v, the L means it pulls the line to 0v when it wants the chip to reset? So 1.8v means it should be working?
                              Resistance for PP2V5_NAND_SSD0 immediately after i remove power is 62 ohms. is 87 ohms 30 seconds later and keeps rising. 1 minute later it's passed 100 ohms.
                              • mon2
                                • Dec 2019
                                • 14156
                                Resistance looks ok.
                                Confirm the voltages for the attached locations on U9580 which creates this 2v5 rail for the SSD.
                                • powerblackout
                                  • Feb 2018
                                  • 109
                                  PPBUS_G3H_SSD1_SNS - 12.3v
                                  PPBUS_G3H_SSD0_SNS - 12.3v
                                  SSD0_VR_P2V5_EN - 0.0v
                                  SSD1_VR_P2V5_EN_R - 0.0v
                                  SSD0_VR_P2V5_EN_r - 0.0v
                                  • mon2
                                    • Dec 2019
                                    • 14156
                                    Remove all power.
                                    What is the resistance to ground for the following ?
                                    SSD1_VR_P2V5_EN
                                    SSD0_VR_P2V5_EN
                                    Technically, these are enable pins for the local 2v5 regulators. If the resistance on this rail is not low, then you could in theory, remove the series resistor (R9098 for SSD1; R9598 for SSD0) bridging the driver & this local TI regulator -> then hard strap the enable pin to be logic high to force it always ON. This in turn should turn on the regulator to power on the SSD (of your choice).
                                    The enable pin will consider a voltage > 1V to enable. You can strap the ENABLE pin to 3v3 on the board.
                                    If you decide to do this, ping back so we can agree on a proper location for this rail.
                                    • powerblackout
                                      • Feb 2018
                                      • 109
                                      SSD1_VR_P2V5_EN - 3.2 megaohms
                                      SSD0_VR_P2V5_EN - 3.1 megaohms
                                      Yes I could force enabling the pins to see if the SSD even works. Would this be a permanent solution?
                                      • mon2
                                        • Dec 2019
                                        • 14156
                                        First, I would test it but gathering that with the power rail always enabled, the battery will drain faster.
                                        However, this could be a case of the chicken and the egg - you need to manually enable the SSD so that you can restore the T2 firmware and after this is resolved, apply the series resistor back onto the logic board and test again.
                                        In theory, this may be the resolution. Very curious and wanting to hear of your success.
                                        • Bmet
                                          MacBook Pro 13 inch A2238 M2 stuck on 5V
                                          by Bmet
                                          I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                                          04-02-2025, 05:02 PM
                                        • Steven Pieter
                                          Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                                          by Steven Pieter
                                          hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                                          11-24-2024, 10:02 AM
                                        • DATATECH85
                                          Macbook Pro A1990 - 820-01041 Stuck at 5V / 0.02A
                                          by DATATECH85
                                          I am currently working on a Macbook Pro A1990 (motherboard 820-01041) which is not charging.
                                          The Macbook consumes 5V and 0.019A at USB-C. There seems to be a partial short-circuit on the PPBUS_G3H rail as I have 0V on this rail.
                                          I've physically separated (by removing F7000 and F7001) PPBUS_G3H and the ISL9240 charging chip to see which side the short is coming from. Removing these fuses gives me 12.6V at the output of the ISL chip (PPVBAT_G3H_CHGR_REG).
                                          However, I can't work out exactly why I don't have the PPBUS_G3H rail.
                                          Here are the values...
                                          07-24-2024, 06:34 AM
                                        • martyjelen
                                          Apple MacBook Pro 16-Inch 2019 - A2141 - stuck at 5V
                                          by martyjelen
                                          Hello, I have this Macbook A2141. It stuck at 5V / 0,075A. I measured all 4 ports, all the same. PPBUS_G3H is present but only 12,3V. Should be 12,6V ? according to this article : https://repair.wiki/w/MacBook_Pro_A2...w_at_5V_repair
                                          PP3v3_G3H_RTC_X is present - 3,3V
                                          PP3v3_G3H_SOCPMU is present - 3,3V
                                          ​What else should I check?
                                          Thank you for your help.
                                          05-05-2025, 01:34 AM
                                        • duwane
                                          MacBook Air A2337 - 820-02016 - Stuck at 5v - Varying current draw - Board had short
                                          by duwane
                                          Hi All.
                                          I have an 820-02016 board (A2337 M1) that has come in for data recovery. Reported as liquid damage, but no visible evidence of any liquid damage.
                                          Board was initially stuck at 5v, and current only spiking occasionally to around 400mA and cycling.
                                          After initial troubleshooting, found that C7800 (which feeds the power rail PP5V_BSTLQ_VOUT_SPMU) was dead short to ground.
                                          Replaced C7800 and short gone. Board still stuck at 5v. Current draw behaviour changed. It now spikes up for a second to around 100mA to 130mA, then drops down to...
                                          10-17-2023, 07:48 PM
