Fuses in Macbook Pro 2019 A2159
  • mon2
    • Dec 2019
    • 14076
    Re: Fuses in Macbook Pro 2019 A2159
    Ok. So the eDRAM switching regulator is NOT enabled.
    Check for the presense of PP3V3_S5 rail which powers the logic that drives the eDRAM rail regulator.
    See attached.
    • mp844
      • Dec 2021
      • 21
      • Poland
      PP3V3_S5 = 3V3, this is at both ends of each of these resistors.
      • mon2
        • Dec 2019
        • 14076
        That is a good sign and is the voltage that powers the logic gates that ENABLE / DISABLE the eDRAM switching regulator.
        Yet, the power rail is being DISABLED.
        See attached. Post the voltages for the signals used to make this decision.
        • mon2
          • Dec 2019
          • 14076
          Also, check if the 1v8 rail is present in the revised attachment location.
          • mp844
            • Dec 2021
            • 21
            • Poland
            R7792 near the U7790 level shifter = 1.2mV, then goes to 100mV for about 10 seconds, spikes to about 1V (fraction of a second, multimeter goes through the ranges) and back to 1.2mV for about 40s, repeat.
            R7792 opposite side of level shifter (upper end on photo) = 1.8V for about 40s, then 0V for about 10s, repeat, similar with golden pad below it from last post.
            R7103 left side whete arrow points = 1.8V for some seconds but unstable, drops to 1.5, 1.2, hundreds of mV, zero, back to 1.8V, no clear pattern.
            R7103 opposite (right side closer to U7712) - fluctuates, no pattern, 0...200mV with possible spike around 1V.
            The above are difficult to measure precisely without oscilloscope hope this helps...
            These times are not rigid, I think as the board warms up they patterns get more chaotic.
            • mon2
              • Dec 2019
              • 14076
              See attached. Interested in the voltage @ L6900.
              • mp844
                • Dec 2021
                • 21
                • Poland
                #27
                3V3, appears steady
                • mon2
                  • Dec 2019
                  • 14076
                  Post the voltage of R7103 from another part of the logic board.
                  • mp844
                    • Dec 2021
                    • 21
                    • Poland
                    #29
                    1.8V for about 40s, then 0v for a few seconds, then 0.3V for a few seconds, then repeat to 1.8V
                    • mon2
                      • Dec 2019
                      • 14076
                      Remove all power. Meter in resistance mode (2k).
                      Check the resistance to ground for the same test point for the 1v8 rail that is pulsing.
                      • mp844
                        • Dec 2021
                        • 21
                        • Poland
                        #31
                        Board drained, 980kOhm in ref to GND
                        • mon2
                          • Dec 2019
                          • 14076
                          Post the voltage of PP3V3_G3H_PMU_VDDMAIN as per attached location.
                          Your 1v8 rail is pulsing ON / OFF. Need to confirm that the INPUT to the regulator that creates this rail is stable or not.
                          There are many spots on the board that can offer this voltage check but the test pad looks convenient.
                          • mp844
                            • Dec 2021
                            • 21
                            • Poland
                            #33
                            Continuous 3.3V there
                            • mon2
                              • Dec 2019
                              • 14076
                              Check the presence of PP1V8_AWAKE.
                              Also, PP1V2_AWAKE.
                              • mp844
                                • Dec 2021
                                • 21
                                • Poland
                                #35
                                PP1V8_AWAKE = continuous 1.8V
                                PP1V2_AWAKE = continuous 1.2V
                                • mon2
                                  • Dec 2019
                                  • 14076
                                  Post the voltage for PP1V8_G3S.
                                  • mp844
                                    • Dec 2021
                                    • 21
                                    • Poland
                                    #37
                                    PP1V8_G3S = 1.8V
                                    note to this and previous 1.8V measurements: every 30-60s the 1.8V goes to zero, jumps to 2.1V momentarily and back to 1.8V for another 30-60s
                                    • mon2
                                      • Dec 2019
                                      • 14076
                                      Post the voltage for the attached.
                                      • mp844
                                        • Dec 2021
                                        • 21
                                        • Poland
                                        #39
                                        +3.3V continuous
                                        • mon2
                                          • Dec 2019
                                          • 14076
                                          See attached to see where we are at.
                                          The power sequence just after this last checked rail is pulsing.
                                          You may have a SMC fault but wait on other comments. Perhaps reflashing the BIOS will help but no direct experience with this area. We should have 2 of these boards in next week for repair so can check and post updates at that time.
                                          The fault could be linked to corrupt T2 firmware but have not yet reflashed such logic board. Believe @Stephen is the pro in this area here in the forum.
                                          But wait for more advice:
                                          https://www.badcaps.net/forum/showthread.php?t=93978
                                          • bouch
                                            unlock macbook air A1932 2019
                                            by bouch
                                            hi
                                            i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                                            i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                                            i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                                            have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                                            I need help or information?
                                            Does anyone have the minat2 activator 1.4 software?
                                            Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                                            Thank yo...
                                            03-12-2025, 10:14 AM
                                          • Eniaro
                                            MacBook Pro 2019 A2159 (2-port) wont boot
                                            by Eniaro
                                            Trackpad clicks.
                                            Plugging in a genuine USB-C charger and any other charger = 20V and charges all the way.
                                            Plugging in a Dell USB-C dock or monitor causes the voltage to cycle endlessly between 5V and 19V
                                            The Caps Lock button doesn't illuminate.
                                            Holding the power button (fingerprint scanner) for 10 seconds stops the trackpad clicking temporarily, but it starts clicking again after 3 seconds.
                                            If I open the lid slightly, the trackpad stops clicking (it seems to be detecting the lid opening/closing).
                                            The keyboard backlight...
                                            11-27-2024, 04:25 PM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                          • kuba2102
                                            MacBook Pro 2019 A2159 Replacing SSD does it need programming?
                                            by kuba2102
                                            Hi. I suspect the SSD has failed on this machine. I couldn't find answers googling it hence my question. Can you just take and replace SSD from another mac 2019 or it need to be programmed with serial numbers etc? Also eg. if my macbook is 128GB and using only one slot/bank for the SSD and another slot/bank is not being used (empty), can you remove the SSD from slot 1 and put it into slot 2, would it work? I know for a fact that those SSD are set in RAID partitions so if arranged in wrong order it's not going to work, but I'm curious if it needs programming also if the SSD can be soldered onto...
                                            09-01-2022, 12:58 PM
                                          • kenzo2
                                            Please help me file Dump Nand Macbook Pro A2159 2 Nand 512GB
                                            by kenzo2
                                            I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
                                            I need dump file MACBOOK PRO A2159
                                            TSB4232(256)
                                            TSB4229(256)
                                            Thanks​
                                            01-11-2025, 04:18 AM
