A2337 new M1 MacBook Air problem Logic Board related, no video backlight 820-02016
  • mon2
    • 14356
    Using the same 600 ohm meter scale setting, touch the meter probes together. What is the resistance in ohms?
    • corintosh
      • Dec 2024
      • 29
      Just checked it and it fluctuates but always comes down to 0.1-0.3 before then randomly going up again.
      I also just saw that there is a component missing that is in the schematics: CP830, it is already missing on the first picture and the board did not have previous work done.
      • corintosh
        • Dec 2024
        • 29
        First of all, happy new year!
        I doubt it is the meter but I cannot find any shorted capacitor, I took off the 14 capcitors from both sides and they all are okay. The resistance still is at ~3.7 ohms.
        How would you proceed now?
        • mon2
          • 14356
          Thank you! Happy New Year to you as well.
          Flux and remove the diode @ DP800. Take a picture of this part for proper orientation when you solder it back onto the board. There is a polarity to diodes.
          After the part is removed, test the resistance to ground on each side of the diode pcb pads. We are trying to isolate the parts on the board to locate the source of this short. That is, is the short before the diode or after the diode?
          • corintosh
            • Dec 2024
            • 29
            So I removed the diode and the resistance to ground with respect to the anode (upper pcb pad) is in the hundreds of kOhms and rising. The resistance to ground wrt the cathode is 3.6 ohms, so the same as before when we measured the suspicious capacitors.
            I had a look which components could also lead to a short resistance path. It seems like there is a resistor (RP832) and some more very small capacitors that are possible candidates.
            Thanks for your patience with me, how would you proceed now?
            • mon2
              • 14356
              Ok. Confirm if you have a component @ RP831. If yes, flux and carefully remove this part. It is a tiny 0402 device so proceed with patience. This will isolate the backlight IC from this equation.
              • corintosh
                • Dec 2024
                • 29
                I was able to remove it on the second try…
                Still 3.7 ohms wenn measuring from ground to the pcb pads where the capacitors were.
                Update: I checked the schematic again and figured it could be a capacitor next to JP600, using the microscope I saw some „spider web“ pattern on the bigger one and took it off.
                The resistance now is 3.4 ohms…
                • mon2
                  • 14356
                  At this stage, the LCD is disconnected, the backlight IC is isolated so it is down to the cluster of remaining caps.
                  To confirm the IC isolation, measure the resistance to ground of CP830 (this is a no stuff capacitor but we can use the SMD pads for measurement). This test should be of a high resistance. Confirm it.
                  Then we are back to the voltage injection again to hunt for who is causing this short. Based on that we should be completely isolated, it is ok to increase the voltage on the injection to say 2 volts or more. Double check all work before proceeding but the guilty party is within the cluster of remaining caps in this cluster. The resistance is fairly low and the part will heat up with the proper injection.
                  • corintosh
                    • Dec 2024
                    • 29
                    Thanks again for your ongoing help and patience, I like to think I am getting somewhat better at this but that would be all to you.
                    I can confirm the IC is isolated 150 kOhms at CP830 wrt ground. The LCD is disconnected, although the connector is still on the logic board.
                    I will check the boardview again to see which capacitors are left and try to find the short using voltage injection and alcohol. I will report back what I find (or don‘t find)
                    • corintosh
                      • Dec 2024
                      • 29
                      I checked every capacitor that is left in the backlight out multiple times injecting up to 3.5V. Nothing changed, no cap dried noticeably faster than the others (that is.. they all did not really dry at all).
                      When swapping the side I also swapped the probes by accident and therefore injected with the red probe to ground.. could this have caused damage?
                      The only thing I noticed after injecting voltage is that the resistance now is at 4.2 ohms so a tiny bit higher.
                      Do you still suspect the remaining 9 capacitors?, if so should I try it with even higher voltage?
                      • mon2
                        • 14356
                        Perhaps. Not sure but let us continue to confirm either way.
                        Suggest to carefully flux and remove the balance of the 9 caps to hunt down the shorted component. Respectively, restore each back onto the board if found to be not shorted.
                        • corintosh
                          • Dec 2024
                          • 29
                          I started removing caps and the first one directly seemed to add on to one low resistance path. It is a tiny 0201 resistor (CW196) and removing it immediatly increased resistance to 6.1 ohms.
                          I do not have a clue how much resistance there should be, so I would not know when to stop. It is probably safe to assume this did not resolve it and I continue removing caps?
                          As for the reassembly I will probably ask somebody more experienced to solder the 0201 and 0402 caps and can only put the bigger ones back. I also decided to buy replacements for all caps I removed because some looked dodgy and they are a couple cents each. They will arrive in a couple of days.
                          • mon2
                            • 14356
                            Still too low for the resistance. Keep plucking.
                            • inflex
                              • Aug 2012
                              • 545
                              Just weighing in here, I've had a lot of these units, and yes, keep removing those caps one by one; eventually you'll probably find one with a crack on the underside. They can be sneaky!
                              YouTube Repair Videos - https://www.youtube.com/user/19PLD73
                              FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
                              • corintosh
                                • Dec 2024
                                • 29
                                First of all thank you for your quick visit, flex and your videos. You are the reason I tried looking up what it could be in the first place, I did not know you are around here as well, what a lovely surprise.
                                I cannot thank you enough for your continuous support. Reading the original thread I thought „lets give it a try with this quality help, it might work“ and I sure learned a lot and had plenty fun.
                                I removed everything. There still is a low resistance path somewhere. At some point, while removing the last caps the resistance went down to 5.4 ohms again.
                                Judging by the boardview there is only the tcon connector (the port on the board, I removed the connector cable) left within the circuit.The pins look fine, I don‘t know if there is still a chance to find and fix it.
                                • mon2
                                  • 14356
                                  If the LCD connector has not been reworked then it is not the fault. There are a lot of caps on this backlight rail. Hate to ask but can you post a list of the caps you have removed in this process? Suspecting that someone has been missed and is the guilty party. For example, the caps in the DESENSE area have been removed?
                                  These are in section F = Backlight Desense Capacitors.
                                  • corintosh
                                    • Dec 2024
                                    • 29
                                    Sure, that is completely fair.
                                    Top side:
                                    CP867 - CP873
                                    CW194, CW195, CW196, CW18D, CW18B, CW18A
                                    CP600 - CP604
                                    Bottom side:
                                    CP860 - CP866
                                    CW18F, CW18E, CW18C, CW197
                                    Also DP800 and RP831 are still off and CP810 and CW1A8 I removed earlier by accident. These are still off as well.
                                    • corintosh
                                      • Dec 2024
                                      • 29
                                      Just checked your example, those should be the five caps next to the display connector CP600 - CP604. I compared my board to the boardview in flex and had all components in PPVOUT_LCDBKLT marked. The caps in there are all off. If there are other caps, that need to be removed they are still on.
                                      Edit:
                                      I also checked each pcb pad under my microscope after I removed the last caps and looked for solder bridges but there weren‘t any. If you want I can make some photos of the areas I removed the caps from. Maybe I am missing something.
                                      If it is not a component I forgot to remove, do you have an Idee what else it could be?
                                      • inflex
                                        • Aug 2012
                                        • 545
                                        Yes, I spent quite a bit of time here in Badcaps, have been here for many years now ( Just don't post a lot ).
                                        Starting to worry that your board might have an internal short at the rate it's going; based on that cooked off inductor in the original posts it might have happened, hopefully not. Looks like Mon2 is guiding you though. Best of luck.
                                        • mon2
                                          • 14356
                                          Yes, do post pics of the logic board with the removed caps. Also a pic of the LCD connector on your logic board.
                                          • ledbylight
                                            M1 A2337 Macbook - No Display, likely due to logic board
                                            by ledbylight
                                            Hi all!
                                            This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
                                            I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
                                            11-04-2024, 06:36 PM
                                          • Guest
                                            A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                            by Guest
                                            Hello all!
                                            Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                            After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                            09-26-2024, 03:31 AM
                                          • mkdj
                                            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
                                            by mkdj
                                            About me, my goal and the equipment I (don't) have:
                                            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
                                            About my issue and my goal:
                                            A friend of mine has a MacBook Air M1 A2337 that does not...
                                            04-03-2025, 08:28 AM
                                          • korben_dallas
                                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                                            by korben_dallas
                                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                                            MY QUESTION:
                                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                                            02-14-2024, 12:23 AM
                                          • Adogabriel100
                                            where to get trusted CD3217. Problem with A2337 Macbook Air
                                            by Adogabriel100
                                            Hey! As the title says. i don't know if this is the right place to ask but i need to get trusted USB C Controllers (CD3217-CD3215) For macs and dont know where to get them. i dont know if you guys know where is a good place to get it.
                                            The thing is that i have a Macbook air A2337 M1 and i dont have a donnor board to get the CD3217. So i try the CD3217 from a A2141 Board and at first, whitout his eprom it does not convert 5v to 20v. then i put the original CD3217 eprom from the A2141 and then the macbook A2337 conver the 5v to 20v but still not turning on. i guess that the CD3217 is...
                                            09-06-2024, 12:06 PM
