Lenovo LA-9641 - shuts down after 3 seconds
  • tolgaaydin
    • Jul 2020
    • 11
    • Bursa
    Hello guys
    I have LA-9641P Motherboard. It shuts down 3 seconds after starting. The power led is on and I think the video card chip and HM chipset are getting hot.
    I have made a few measurements below but I need your help and guidance. I would appreciate if you could help me, thanks in advance.
    Note: This article was created with translate, I apologize for any mistakes.
    PQ301 - (P CH Mosfet)
    Drain - 19.5V
    Source - 19.5V
    Gate - 7.7V
    PR301 - 19v
    PL301 - 19V
    PL302 - 2.3V
    PL803 - 0V (beeping at the bell)
    PL605 - (beeping at the bell)
    PL402 3.2V (There is voltage before starting) 320 Ω
    PL501 1.2V (Voltage goes out after start) 315 Ω, 320 Ω, 330 Ω ~
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Lenovo LA-9641 - shuts down after 3 seconds
    PL803/605 are low voltage,high current rails-so will show low resistance. Measure exact resistance on these two coil in Ohms mode(not in diode mode). PQ301 reading is correct. What about PL404?? PL501 voltage should be stable 1.35V as this mb runs on DDR3-L memory.
    • lapfix
      • Mar 2020
      • 2751
      • my workshop
      Hello my friend
      Why you ask for resistance and not diode mode ! is it better !
      You say : high current rails= low resistance..can you you more explain please , thank you
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        @lapfix why high current rail should have low resistance-please read this article
        https://resources.altium.com/p/why-p...-low-impedance
        Resistance is always measured in Ohms-so you should use ohms mode to measure it. As simple as that. When the resistance is too low(the case being discussed here), diode mode may misguide you in thinking its a short to gnd. Nowing exact resistance in ohms is very critical on SOC/Gaming laptops. We all have seen enough boards being damaged by many people thinking its a short to gnd.
        • tolgaaydin
          • Jul 2020
          • 11
          • Bursa
          Hello, thank you for your time.
          PL 803 - 1.1Ω - firstly gets 1.6V, then drops to .925mV.
          PL 605 - 1.2Ω - .949mV
          PL404 - 75 kΩ - 5v
          PL701 - 53Ω - 1.1v (coil close to ram slots)
          note: my dc regulated power supply is not pirated. I'm testing with the original adapter.
          • tolgaaydin
            • Jul 2020
            • 11
            • Bursa
            can anyone help me?
              • 21487
              Originally posted by tolgaaydin
              can anyone help me?
              Resistance measurements should be done with NO power attached.Take the same measurements again
              • tolgaaydin
                • Jul 2020
                • 11
                • Bursa
                Hello
                ohm measurements taken without power.
                I cleaned the motherboard with alcohol. I tried to fix what I saw as cold solder and dried it with hot air.
                There is an image on the screen but no backlight.
                • tolgaaydin
                  • Jul 2020
                  • 11
                  • Bursa
                  Hello
                  I tested it with another broken lcd panel in my hand. The image looks fine. What do I need to measure in the panel part to solve the backlight problem?
                  • mon2
                    • 14599
                    Remove all power.
                    Meter in resistance mode (2k).
                    Check and post the resistance to ground of pins 1&2 on lcd connector on logic board.
                    What is the reading with non-working display? Reading with working display?
                    If you have a working backlight on one lcd panel then the issue is with the lcd panel.
                    With the display with backlight that works, does the computer remain on or still goes off after 3 seconds?
                    • doejohn11
                      Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                      by doejohn11
                      Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                      It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                      04-19-2025, 07:38 AM
                    • solveit68
                      Lenovo L580 20LW-0010GE shuts down after a few seconds
                      by solveit68
                      Hello together,
                      I am hoping for some tips here to repair a notebook.
                      The notebook has following issue:
                      After starting the notebook it shut down after a few seconds.
                      Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
                      The time until shutdown varies slightly.
                      What I've tried so far:
                      - cmos cleared
                      - removed all components that are not essential for motherboard testing including keyboard and touchpad
                      - ram exchanged
                      - same behaviour with power supply or battery...
                      07-21-2023, 01:04 PM
                    • Thermaltake
                      Lenovo X201 shuts down after few seconds
                      by Thermaltake
                      Hi, I got x201 Lenovo, and it powers up just first time I insert AC in it, and shuts down after few seconds no matter if it's in BIOS or on boot screen.
                      And after that I can't turn it On again, I need to unplug AC and plug it back and then it powers up but shuts down after few seconds again. Any clue what that can be ? I got it like that.
                      05-01-2021, 12:05 PM
                    • liquidzorch
                      Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
                      by liquidzorch
                      Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
                      10-18-2024, 05:19 PM
                    • chaos-theory
                      Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                      by chaos-theory
                      I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                      Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                      03-14-2025, 05:37 PM
