A1708 stuck @ 20V, 34mA on charger
  • mon2
    • Dec 2019
    • 14307
    Hi. Welcome feedback on this logic board.
    820-00840
    Client complained that it was not charging the battery. We originally took the logic board apart for measurements and found the logic board was working ok. Gave it back to the client and requested they bring it back for a battery replacement (charge cycles ~950 on the original battery).
    Now the logic board is not booting, much like their original complaint about it being flaky.
    Charger shows 20v @ 34mA / 33mA on Type C meter.
    PPBUS_G3H @ 0v. No shorts. Current sense resistors into / exit on U7000 are measuring ok.
    TBA_AUX_DET @ 5v1
    D6905, pin #2 @ 20v5
    PP3V3_G3H @ 3v42
    Replaced mosfet @ Q7030 with belief it was shorted (gate & drain). However it may have been my error in measurement as the mosfet, after removal from the PCB, was fine on the resistance checks.
    U7000 is a nasty WLCSP package so unable to probe all points.
    Original U7000 = ISL9239HI. Sourced and replaced with ISL9239C0 from Mobile Sentrix. Was a bit reluctant to use the 'C0' for the 'HI' but many websites are listing 'C0' as a valid replacement for the A1708 logic boards.
    No change after the U7000 replacement.
    No voltage on L7030.
    No battery is attached to the logic board.
    Does this logic board require a battery to boot ?
    Any ideas on why PPBUS_G3H remains OFF ?
    Update #1:
    Attached the now draining (fresh) battery from Mobile Sentrix. The voltage on the battery is about 11v5. This is the voltage that appears on PPBUS_G3H.
    The logic board continues to consume ~34-36mA. Have fan spin upon adapter connection, chimes quickly and see the battery icon requesting to charge the battery. Then the display goes dark.
    Update # 2:
    Thanks to:
    https://repair.wiki/w/A1708_2016,_20...ar_MacBook_Pro
    PP5V_S4 is missing but not shorted
    Yup. That is this logic board as well. Investigating this now.
    L7670 (PP5V_S4) is @ 0V.
    L7690 (PP3V3_S5) is also @ 0V.
    This makes sense since, both rails are being created by U7650 (TPS51980A) which takes as input, PPBUS_G3H. However, PPBUS_G3H is @ 0V.
    So this cannot be the fault.
  • mon2
    • Dec 2019
    • 14307
    Re: A1708 stuck @ 20V, 34mA on charger
    SMB_PMIC_SDA is not shorted to ground (~7k5 resistance) but is showing ~0v8 on the SDA line.
    The local pull-up is present for the SDA line @ R5380.
    SMB_PMIC_SCL is showing ~3v3.
    Could the SMC chip be defective (U7800; SN650839ZAJ) or U5000 ?
    Will replace R5380 tomorrow to rule out this component. Resistance checks out fine for this pull-up.
    • mon2
      • Dec 2019
      • 14307
      My Peter Parker sense is tingling. SMBUS_SMC_5_G3H_SDA communication line, that is stuck low @ 0v8 is also mated with SMBUS_BATT_SDA. This party line is then mated with the battery connector and also a local TVS diode (D6950) to protect transients on the SCL & SDA lines.
      The TVS diode @ D6950 looks like a possible candidate for this fault. Will reflow and/or remove to confirm.
      • mon2
        • Dec 2019
        • 14307
        Removed D6950 off the board.
        We have PPBUS_G3H !!!!!!!!!!
        After removing D6950, the resistance to ground increased for the SMBUS_BATT_SDA rail (and also for SMBUS_BATT_SCL).
        Type C meter now climbs much higher than the ~35mA that was not allowing for the board to boot.
        So, U7000 + mosfet (Q7030) were both replaced. Numerous parts on this SMBUS line were reflowed but could not fix this fault. In hindsight, do not believe that either of these parts were to blame and did not require to be replaced. The SMBUS interface was being pulled down and prevented for the proper communication by the SMC (SMC bus master) with this slave switching buck regulator.
        PPBUS_G3H remained OFF (about 20-30mV).
        Removing the TVS diode @ D6950 now allows for a healthy voltage @ PPBUS_G3H.
        Have some fresh TVS diodes in transit from Arrow to replace and ship out this computer
        RCLAMP3552T.TNT
        SEMTECH
        https://www.arrow.com/en/products/rc...2t.tnt/semtech
        • ugamazing
          • Jun 2013
          • 166
          • usa
          Awesome job, way to go! Been following this one.
          • motormayhem
            Lenovo T460 Only Charges on One Charger
            by motormayhem
            Laptop Question
            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
            05-12-2023, 01:46 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • flat-earther
            how to prevent a connected charger from draining battery when not charging?
            by flat-earther
            I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
            So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
            but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
            So the battery is backfeeding the charger and being drained.
            How can I prevent...
            08-07-2025, 01:04 PM
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • Johndill
            Dell Inspiron 7567 LA-D993P odd charger issue
            by Johndill
            Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
            There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
            I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
            Here are the tested scenarios:
            1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
            2. With the laptop off, plug in charger (LED says on) & the front charging...
            11-16-2022, 10:55 PM
