Help! Macbook A1707 turn on without image..
  • oemelectronic
    • Sep 2019
    • 33
    • peru
    hi friend
    i have Macbook A1707 820-00281 power but no imagen
    PPBUS_G3H : 12.45volt
    PP3V3_G3H : 3.20 volt
    PP3V3_S5 : 3.24 volt
    PP5V_S4 : 5.05 volt
    phase coils 0.60 volt
    please help friends
  • mon2
    • Dec 2019
    • 13829
    Re: Help! Macbook A1707 turn on without image..
    Does the keyboard CAPS green light turn on / off?
    Shine a flashlight to the display front and sides.
    Can you see any graphics?
    The A1707 has flexgate issues. Check the internet for more details.
    • oemelectronic
      • Sep 2019
      • 33
      • peru
      hi dear thanks!!
      no CAPS keyboard light
      neither sides of the screen
      • mon2
        • Dec 2019
        • 13829
        Can you perform the SMC reset upon power up?
        Do you have a usb type C meter?
        What is the voltage & current draw as shown with the type C meter?
        • oemelectronic
          • Sep 2019
          • 33
          • peru
          hi dear
          usb type c test: 19vot 1.4amp working mainborad
          mainboard works take cpu temperature.
          TODAY discover
          the moment you turn on it has voltage PHASE COILS. The screen turns on, but after 5 seconds the phase coils voltage disappears and the screen turns off.
          but the mainboard is still working fan and cpu
          • mon2
            • Dec 2019
            • 13829
            That is a good sign on the current draw.
            When the screen turns on - do you see the graphics ?
            When the screen turns OFF, is it only the backlight is gone or the whole computer turns OFF? To test the backlight idea, apply a flashlight after the screen goes dark on the front face. Can you see the graphics ?
            Moving forward, which phase coils lose the voltage ? Post their exact locations from the boardview files and the schematic.
            Coils should be 'Lxxx' format.
            • oemelectronic
              • Sep 2019
              • 33
              • peru
              hi dear
              are flexgate issues
              have picture. but it has another problem not WiFi
              can't turn on wifi. will be software?
              THANKS
              • mon2
                • Dec 2019
                • 13829
                You may have flexgate issues but cannot be sure since you have the display visible with a flashlight.
                For sure, your backlight is not ON.
                Check and post the voltage readings for:
                1) F8400, pin # 1. This should be PPBUS_G3H. Value ?
                2) F8400, pin # 2. PPVIN_S0SW_LCDBKLT_FET. Value ?
                3) PPVOUT_S0_LCDBKLT.
                On the WIFI not working:
                4) PP3V3_S4_WLAN_SW
                5) PP3V3_S4_WLAN
                6) SMC_WIFI_PWR_EN
                • oemelectronic
                  • Sep 2019
                  • 33
                  • peru
                  HI DEAR MON2
                  video works now, it was flex problem
                  now i don't have wifi disabled, but ok bluetooth
                  here the values :
                  4) PP3V3_S4_WLAN_SW : 3.0VOLT
                  5) PP3V3_S4_WLAN : 3.2VOLT
                  6) SMC_WIFI_PWR_EN : 3.2VOLT
                  thanks
                  • mon2
                    • Dec 2019
                    • 13829
                    How did you fix the flex problem? New display or replace the flex cables? Facing the same issue with a1707 820-00840 logic board.
                    • oemelectronic
                      • Sep 2019
                      • 33
                      • peru
                      Reflux connector solved video
                      Macbook A1707 820-00281 is logic.
                      no wifi today
                      thanks
                      • mon2
                        • Dec 2019
                        • 13829
                        hi.
                        1) voltage of PP3V3_S4_WLAN_SW ?
                        2) check and post the voltages on the WIFI rom (see attached).
                        3) from the schematic, it appears that the bluetooth (BT) and WIFI functions are supported by the single module. That is, if BT is working then WIFI should be possible as well. Just that the BT and WIFI functions appear to have different and independent power rails.
                        • oemelectronic
                          • Sep 2019
                          • 33
                          • peru
                          hi dear MON2
                          happy year 2022 first
                          1) voltage of PP3V3_S4_WLAN_SW : 3.27VOLT
                          2) check and post the voltages on the WIFI rom (picture add) not have volt.
                          3). BLUETHOOTH WORKING. BUT NO WIFI
                          THANKS
                          • mon2
                            • Dec 2019
                            • 13829
                            Hi. Happy New Year to you as well.
                            The Vcc is a good voltage to power the WIFI flash memory device.
                            However, no voltage on the SPI interface pins is odd. Perhaps others can comment on this area. Perhaps the SPI flash rom is only used during first power on and then no activity after the boot cycle?
                            If possible, try to measure or check for activity upon first power on.
                            Here a low cost logic analyzer could be helpful.
                            • oemelectronic
                              • Sep 2019
                              • 33
                              • peru
                              yes dear
                              please help friend
                              thanks
                              • oemelectronic
                                • Sep 2019
                                • 33
                                • peru
                                HI DEAR
                                It has something to do with it, I try it without connecting the lcd screen, because it is broken.
                                • oemelectronic
                                  • Sep 2019
                                  • 33
                                  • peru
                                  HI DEAR will this?
                                  https://logi.wiki/index.php/T1_MacBo...IC_Replacement
                                  NEED REMPLACE IC U3710
                                  • mon2
                                    • Dec 2019
                                    • 13829
                                    Interesting link on WiFi details.
                                    What does the WIFI screen show for your logic board?
                                    Can you post the screen pic to compare with the linked page?
                                    The reference page implies 3 devices must be replaced as they are paired.
                                    The eeprom (flash) that has no voltage on the SPI pins is rather low density. It must be to store scanned access points, mac address, etc. Nevertheless, it is important.
                                    • oemelectronic
                                      • Sep 2019
                                      • 33
                                      • peru
                                      Hi dear.
                                      Add picture. Wifi working. But no search red
