Help! Macbook A1707 turn on without image..
  • oemelectronic
    • Sep 2019
    • 33
    • peru
    hi friend
    i have Macbook A1707 820-00281 power but no imagen
    PPBUS_G3H : 12.45volt
    PP3V3_G3H : 3.20 volt
    PP3V3_S5 : 3.24 volt
    PP5V_S4 : 5.05 volt
    phase coils 0.60 volt
    please help friends
  • mon2
    • Dec 2019
    • 14512
    Re: Help! Macbook A1707 turn on without image..
    Does the keyboard CAPS green light turn on / off?
    Shine a flashlight to the display front and sides.
    Can you see any graphics?
    The A1707 has flexgate issues. Check the internet for more details.
    • oemelectronic
      • Sep 2019
      • 33
      • peru
      hi dear thanks!!
      no CAPS keyboard light
      neither sides of the screen
      • mon2
        • Dec 2019
        • 14512
        Can you perform the SMC reset upon power up?
        Do you have a usb type C meter?
        What is the voltage & current draw as shown with the type C meter?
        • oemelectronic
          • Sep 2019
          • 33
          • peru
          hi dear
          usb type c test: 19vot 1.4amp working mainborad
          mainboard works take cpu temperature.
          TODAY discover
          the moment you turn on it has voltage PHASE COILS. The screen turns on, but after 5 seconds the phase coils voltage disappears and the screen turns off.
          but the mainboard is still working fan and cpu
          • mon2
            • Dec 2019
            • 14512
            That is a good sign on the current draw.
            When the screen turns on - do you see the graphics ?
            When the screen turns OFF, is it only the backlight is gone or the whole computer turns OFF? To test the backlight idea, apply a flashlight after the screen goes dark on the front face. Can you see the graphics ?
            Moving forward, which phase coils lose the voltage ? Post their exact locations from the boardview files and the schematic.
            Coils should be 'Lxxx' format.
            • oemelectronic
              • Sep 2019
              • 33
              • peru
              hi dear
              are flexgate issues
              have picture. but it has another problem not WiFi
              can't turn on wifi. will be software?
              THANKS
              • mon2
                • Dec 2019
                • 14512
                You may have flexgate issues but cannot be sure since you have the display visible with a flashlight.
                For sure, your backlight is not ON.
                Check and post the voltage readings for:
                1) F8400, pin # 1. This should be PPBUS_G3H. Value ?
                2) F8400, pin # 2. PPVIN_S0SW_LCDBKLT_FET. Value ?
                3) PPVOUT_S0_LCDBKLT.
                On the WIFI not working:
                4) PP3V3_S4_WLAN_SW
                5) PP3V3_S4_WLAN
                6) SMC_WIFI_PWR_EN
                • oemelectronic
                  • Sep 2019
                  • 33
                  • peru
                  HI DEAR MON2
                  video works now, it was flex problem
                  now i don't have wifi disabled, but ok bluetooth
                  here the values :
                  4) PP3V3_S4_WLAN_SW : 3.0VOLT
                  5) PP3V3_S4_WLAN : 3.2VOLT
                  6) SMC_WIFI_PWR_EN : 3.2VOLT
                  thanks
                  • mon2
                    • Dec 2019
                    • 14512
                    How did you fix the flex problem? New display or replace the flex cables? Facing the same issue with a1707 820-00840 logic board.
                    • oemelectronic
                      • Sep 2019
                      • 33
                      • peru
                      Reflux connector solved video
                      Macbook A1707 820-00281 is logic.
                      no wifi today
                      thanks
                      • mon2
                        • Dec 2019
                        • 14512
                        hi.
                        1) voltage of PP3V3_S4_WLAN_SW ?
                        2) check and post the voltages on the WIFI rom (see attached).
                        3) from the schematic, it appears that the bluetooth (BT) and WIFI functions are supported by the single module. That is, if BT is working then WIFI should be possible as well. Just that the BT and WIFI functions appear to have different and independent power rails.
                        • oemelectronic
                          • Sep 2019
                          • 33
                          • peru
                          hi dear MON2
                          happy year 2022 first
                          1) voltage of PP3V3_S4_WLAN_SW : 3.27VOLT
                          2) check and post the voltages on the WIFI rom (picture add) not have volt.
                          3). BLUETHOOTH WORKING. BUT NO WIFI
                          THANKS
                          • mon2
                            • Dec 2019
                            • 14512
                            Hi. Happy New Year to you as well.
                            The Vcc is a good voltage to power the WIFI flash memory device.
                            However, no voltage on the SPI interface pins is odd. Perhaps others can comment on this area. Perhaps the SPI flash rom is only used during first power on and then no activity after the boot cycle?
                            If possible, try to measure or check for activity upon first power on.
                            Here a low cost logic analyzer could be helpful.
                            • oemelectronic
                              • Sep 2019
                              • 33
                              • peru
                              yes dear
                              please help friend
                              thanks
                              • oemelectronic
                                • Sep 2019
                                • 33
                                • peru
                                HI DEAR
                                It has something to do with it, I try it without connecting the lcd screen, because it is broken.
                                • oemelectronic
                                  • Sep 2019
                                  • 33
                                  • peru
                                  HI DEAR will this?
                                  https://logi.wiki/index.php/T1_MacBo...IC_Replacement
                                  NEED REMPLACE IC U3710
                                  • mon2
                                    • Dec 2019
                                    • 14512
                                    Interesting link on WiFi details.
                                    What does the WIFI screen show for your logic board?
                                    Can you post the screen pic to compare with the linked page?
                                    The reference page implies 3 devices must be replaced as they are paired.
                                    The eeprom (flash) that has no voltage on the SPI pins is rather low density. It must be to store scanned access points, mac address, etc. Nevertheless, it is important.
                                    • oemelectronic
                                      • Sep 2019
                                      • 33
                                      • peru
                                      Hi dear.
                                      Add picture. Wifi working. But no search red
                                      • gugutm
                                        Macbook Pro 15" A1707 820-00928-04 no chime,no boot,no image 19.92v 0.900a
                                        by gugutm
                                        Hi everyone
                                        Please bear with me as I am not yet a pro with some of these issues. Trying to watch a lot of youtube videos and master myself but there are things which I cannot fix and would like to ask for a help from the pro people.
                                        Got macbook a1707 board no 820-00928-04
                                        It had a water damage on couple components, green staff corrosion,
                                        C7680 ppbus _hs_oth3v3, tested for short I believe its okey red prob on ground, getting 2.512kilo om
                                        C7251 ppbus_hs_cpu done the same and getting about the same, 2.506kilo om
                                        U5400 some corrosion, I clear all this...
                                        08-05-2023, 04:58 AM
                                      • CG_Dionysos
                                        MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                                        by CG_Dionysos
                                        I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                                        • Model: A1707
                                        • 15-inch, Mid 2017
                                        • 3.1 GHz Core i7
                                        • 16 GB RAM
                                        • Radeon Pro 560
                                        • 1 TB SSD
                                        • Board number: 820-00928-A
                                        I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                                        Thanks in advance!
                                        Greetings from Germany...
                                        09-16-2025, 06:43 AM
                                      • leonemax81
                                        Macbook a1707 820-00281 Battery no Power
                                        by leonemax81
                                        Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
                                        08-23-2024, 09:24 AM
                                      • Ugur87
                                        MacBook Air M4 A3240 Brand New Water Damage no Image
                                        by Ugur87
                                        I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                        08-28-2025, 01:09 PM
                                      • sofles
                                        Macbook a1707 2017 model 820-00928 GPU issue
                                        by sofles
                                        Hello there
                                        I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
                                        I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
                                        11-21-2024, 05:25 AM
