Hp 470 g2 - la-b181p
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Hello!
    Today i got a laptop that prior work has been done it the BIOS chip was removed, and 1 capacitor wasn't connected .
    So i re-purpose those .
    Now, when you plug in the charger, the "light" on the board itself (as you may now its a white blink led) , it will sudden rapid turns off turns off, like flickr , not the general code ,as we now (with beeps or indication lights).
    Just flickrs for a split second and cuts off.
    No power on ,no fan spin , nothing i suspect something from mosfet , with somewhere to be problem with ground.
    But my main furstration is that as soon as you plug in the charger, i cannnot measure not even with ground the charger it self, i mean you have 8 points that the DC Jack goes to on the board, i plug the multimeter (negative) to a hole/ ground and the red wire to , establish a connectionwith dc-jack and see how much volts are coming in .
    But nothing is coming in ...
    (The charger is 100% working without problem etc. tried 2-3 different chargers).
    So i suspect the protection goes on ?
    I don't know where to begin.
    i even found a schematic.
  • Acnologia
    • Dec 2016
    • 421
    • Poland
    Re: Hp 470 g2 - la-b181p
    Here is video
    https://vimeo.com/651058480
    • Acnologia
      • Dec 2016
      • 421
      • Poland
      New video...
      https://vimeo.com/651081448
      Non stop blinking light.
      • Acnologia
        • Dec 2016
        • 421
        • Poland
        Plug in battery , orange light comes on volts go up , i believe it's charging the battery just fine.
        https://vimeo.com/651081430
        • Acnologia
          • Dec 2016
          • 421
          • Poland
          When i press the power button i have to squize it a little more than general , and you can see the white light comes on , but keeps blinking...
          Tried good RAM (DDR3L + DDR3) both working 100% , just in case this was the problem.
          But again nothing.....
          Keeps blinking white....
          I read the BIOS chip to have it just in case. https://www.badcaps.net/forum/showpo...4&postcount=79 But i believe this is not the problem ?
          • mon2
            • Dec 2019
            • 14231
            From the internet, white blinking light means low battery detected. For now, remove the battery.
            Does the vin rail from adapter remain stable when connected to the logic board? This is the first interconnect to the board.
            When logic board is on, can you measure the voltages at each coil to ground?
            • Acnologia
              • Dec 2016
              • 421
              • Poland
              I haven't plugged in the battery.
              The board is bare naked. I just tested the battery in case it's charging.
              So far all good.
              But again , nothing else is showing...
              • Acnologia
                • Dec 2016
                • 421
                • Poland
                I see 7 coils inthe front and none on the back.
                Most coils give me strange measuerments.
                • Acnologia
                  • Dec 2016
                  • 421
                  • Poland
                  Extra video with coil check.
                  https://vimeo.com/651116285
                    • 20952
                    just type out and post the results here mate, why take us away from the site to watch through a video.Reading the results here takes seconds
                    • mon2
                      • Dec 2019
                      • 14231
                      See attached.
                      Check & post the voltage readings for the requested locations.
                      We are checking to see how far the DCIN (adapter) voltage travels through the logic board.
                      • Acnologia
                        • Dec 2016
                        • 421
                        • Poland
                        The videos are just for showing in specific place what i get.
                        I will try and make sure the results , are on point and post them .
                        As soon as i start from somewhere...
                        • Acnologia
                          • Dec 2016
                          • 421
                          • Poland
                          See attached.
                          If i am getting it straight ( as you understand still learning ) .
                          You want me to measure the points : PQ102 ,PQ101, PR102.
                          Correct?
                          • Acnologia
                            • Dec 2016
                            • 421
                            • Poland
                            PQ 105
                            Entire one side has 2,53volt
                            The other side 19,65 volt
                            all stable measurments
                            PQ101
                            Entire one side 19,65
                            Entire other side 19,65 except last pin 6,12
                            PU102 and PQ102. I draw them here
                            • Acnologia
                              • Dec 2016
                              • 421
                              • Poland
                              and as i said, before it was blinking white light...
                              Now when you press the power button , it turns on the white light (and the light on the power button ribbon cable) stays on for 2-3 sec. and then sudden cuts off
                              (No fan spin, no heat anywhere)
                              • Acnologia
                                • Dec 2016
                                • 421
                                • Poland
                                I've tried more than 10 BIOS, all from forum, different threads ,some make the laptop completey dead. Without not even light ,but some make the laptop go ,to blinking white led mode (continous) non stop blinking (so it's not a code) . But again no fan spin , nothing on screen.
                                Some BIOS, make the laptop also go to a point that is showing steady white light , and then after 5-6 cuts off completely and goes dead.
                                No component is heating up (from bare hands)
                                • Acnologia
                                  • Dec 2016
                                  • 421
                                  • Poland
                                  Any kind of help ?
                                  • Acnologia
                                    • Dec 2016
                                    • 421
                                    • Poland
                                    Maybe last minute help ? I think i will throw the board...
                                    • flat-earther
                                      ASUS X54H laptop thinks it's always charging even with charger unplugged
                                      by flat-earther
                                      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                                      Windows also shows ''Plugged in'' when charger is not connected.
                                      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                                      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                                      If I let battery run out and say it has 3% Windows will...
                                      06-24-2025, 09:32 AM
                                    • motormayhem
                                      Lenovo T460 Only Charges on One Charger
                                      by motormayhem
                                      Laptop Question
                                      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                      05-12-2023, 01:46 PM
                                      NVDC charger configuration...
                                      11-05-2024, 03:28 PM
                                    • flat-earther
                                      how to prevent a connected charger from draining battery when not charging?
                                      by flat-earther
                                      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                      So the battery is backfeeding the charger and being drained.
                                      How can I prevent...
                                      08-07-2025, 01:04 PM
                                    • Johndill
                                      Dell Inspiron 7567 LA-D993P odd charger issue
                                      by Johndill
                                      Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                                      There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                                      I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                                      Here are the tested scenarios:
                                      1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                                      2. With the laptop off, plug in charger (LED says on) & the front charging...
                                      11-16-2022, 10:55 PM
