820-2936 PPVCORE_S0_CPU issue.
  • Francisco.s
    • 691
    • Spain
    As the tittle says this board has CPUIMVP_VR_ON, but no PPVCORE_S0_CPU.
    I replaced the pwm MAX17511 chip but nothing changes.
    An intersting function with this chip is that you can force the output for PPVCORE_S0_CPU to be 1.05V, so I have grounded pin 1 of R7469 and tested that MAX17511 works as expected, but the board still no POST.
    From datasheet:
    Thermal-Sense Input for Regulator A. Connect THERMA to a resistor/thermistor-
    divider network between V CC and THERMA to analog ground. The VR_HOT# is
    pulled low when the voltage at THERMA or THERMB drops below 0.5 x V CC .
    If THERMA is held low at startup, REG A is forced in to non-zero V BOOT mode with
    an output voltage of 1.05V (MAX17411/MAX17511/MAX17511T)
    A good bios dump have been tested, just in case.
    Anyone managed to solve a similar issue?
    Seems the same issue like in this post:
    https://www.badcaps.net/forum/showthread.php?t=74405
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
    🛠 Original Issue
    The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
  • elmark
    HP 15-cw1002ua strange keyboard issue
    by elmark
    HP Pavilion 15-CW1002UA
    S/N 5CD0251CBC
    P/N 7KE54EA
    Hello guys!
    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
    It powers on OK and has no other issues except the following:
    • CAPS LOCK does not work at all
    • Fn button toggles Flight Mode
    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
    • (with SHIFT pressed: 't%' and 'y^' respectively)
    I initially thought it was a keyboard malfunction (internal short, etc.),
    but when I press and hold...
    06-27-2025, 01:10 AM
  • Simone Vergani
    Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
    by Simone Vergani
    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
    To assist with troubleshooting, I'm attaching two power circuit schematics:
    • Power
    03-05-2025, 02:25 PM
  • wizard13
    Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
    by wizard13
    I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
    I have checked the forum and the available documentation but could not find a solution specific to my issue.
    • Brand & Model: Dynabook Satellite Pro C50D-B-100
    • Part Number (P/N): PYU13E-00C00PFR
    • Serial Number (S/N): 22028896H
    • System Configuration (SC): A1PYU13E1127
    • Motherboard Model: IP3_ACN16_MB_V21_20211222A
    • Power Input: DC 19V –
    02-28-2025, 02:43 AM
