820-00840-A PP3V3_G3H at 2.26V
  • Jenzo
    • Jul 2019
    • 135
    • Belgium
    Hey everyone,
    Long story short;
    No PP3V3_G3H
    PPVIN_G3H_P3V3GH was way too low, turned out to be C7078
    Now my PP3V3_G3H is at 2.26V, and I honestly have no clue where to look.
    Removed R6999 to check, I have 3,3v coming from PP3V3_G3H_VR. Does this mean U6990 is good for sure? Or what should I check to find the cause of this voltage drop.
    Thank you in advance!
  • mon2
    • 14672
    Re: 820-00840-A PP3V3_G3H at 2.26V
    hi.
    Yes.
    With R6999 out, you have isolated the voltage rail provider (left side) and the voltage rail consumer (right side) of the logic board.
    Remove all power.
    With your meter in resistance mode, check the resistance to ground on R6999, pin 2 pad. You must have a low resistance here as the voltage rail tanks when R6999 is soldered back.
    What is the resistance on the pad to ground ? Since 300mA is max for this dc-dc switcher IC, the present load must be consuming > 300 mA to droop to 2v26.
    • Jenzo
      • Jul 2019
      • 135
      • Belgium
      Hey, sorry took a while to get back to you, was out sick for 2 days.
      600mA on pin 2. What would be the best way to find out what's causing this? As far as I can see on the schematic/boardview there's a lot on this line.
      • mon2
        • 14672
        Go here and find your logic board. Then place your meter in diode mode. Remove all power.
        Then place the RED meter to ground.
        Measure each point (BLACK meter lead) noted in the following webpage for the diode reading. Compare against the posted known good diode value.
        https://logi.wiki/index.php/MacBook_...e_Measurements
        Aside from the above, I would recommend using a power supply to inject a low voltage on this rail to see if there are shorted caps. Others may have better suggestions. Be sure there are no obvious liquid shorts that may be causing this excessive current draw.
        Since this rail is 3v3 if normal, the injection should be lower than this value like 1v0. If you have a thermal camera, it is possible that this process will show the problem as a heated part. Alcohol dabs with q-tip also works well - as the part heats up, the alcohol will evaporate quickly as compared to normal parts.
        Again, only my suggestion but let us wait to learn more about your logic board with the diode readings.
        On the voltage injection, let me link a good video on this topic. Will update this thread after locating the one we used to learn from at the shop.
        https://youtu.be/EWuzmIz7hOE
        NB: If you do proceed with this method, keep the voltage lower than the 3v3. Recommend 1v0 and only slightly increase if required to locate the possible shorted capacitor / part. For now, start with the diode readings.
        • Jenzo
          • Jul 2019
          • 135
          • Belgium
          Thank you for the info, I had no idea of this wiki's existence. This will be of great use in the future.
          So, the diode mode readings gave nothing out of the ordinary. On average they were a little bit higher then the example on the wiki, but this is probably because I'm using a cheaper multimeter. (Or because the measurements on the wiki are taken on a 820-00875, although it should be the same as the 820-00840). I'll take my good one from work coming Tuesday just to make sure.
          I have tried the voltage injection as well, at 1v, 1amp, but it took 0amp. Assuming this is because I don't have a direct/full short to ground?
          Really appreciating you helping me out by the way, this is learning me a lot.
          • Jenzo
            • Jul 2019
            • 135
            • Belgium
            I had the idea it might have been the U7000 (ISL9239), replaced it, problem remains exactly the same.
            One thing I've noticed is depending on which usb-port I plug in the charger, either PP3V3_UPC_XA_LDO or PP3V3_UPC_XB_LDO will be at 2.26v, and the other one steady at 3.3v. Might this be a hint to where the problem might be?
            • Jenzo
              • Jul 2019
              • 135
              • Belgium
              Finally figured it out. U7000 and D6905 were a problem. Replaced them both, have a fully working board now. Thanks for helping!
              • MisterAIL
                820-00840 / No boot / PP3V3_G3H Short to ground
                by MisterAIL
                Firstly sorry for my english, french guy inside.
                I brought a macbook pro A1708 - 820-00840 logic board, wasn't powering on.
                History is a day, nothing happened when opening the laptop.
                Nothing special inside, no corrosion, no liquid damage, never opened.
                First, with the logicboard alone on the desk, mesures are :
                5v017 and 0.000 amp. nothing else.
                Finding a short on the PP3V3_G3H_VR, but not on the PP3V3_G3H (0.540 on diode mode), PPDCIN_G3H_CHGR_R present (5,1 volts) PPVIN_G3H_P3V3G3H around 4.1 volts. PM_EN_P3V3_G3H...
                10-13-2021, 11:42 AM
              • adelage
                220v Led strip flickering
                by adelage
                Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                I know that the best solution would be to get a voltage...
                11-03-2024, 09:49 AM
              • nassih
                a1708 820-00840 missing PPBUS_G3H
                by nassih
                hello! I want to open a new topic about MacBook Pro a1708 820-00840 no power giving me some issues.missing PPBUS_G3H
                state before replacing some components:c7078,c7062 was shorted,u6990,d6905
                all this line are not present: USB meter show 5.2v 0amp
                PPVIN_G3H_P3V3G3H : 0.23
                PM_EN_P3V3_G3H_R : 0.12v
                PP3V3_G3H : 0.2
                PPBUS_G3H : 0.02
                NOW i have : USB meter show 20.1v 0.08amp
                PPVIN_G3H_P3V3G3H : 19.75v
                PM_EN_P3V3_G3H_R : 5v
                PP3V3_G3H : 3.4v
                PPBUS_G3H : 0.132v
                03-02-2023, 01:13 PM
              • nassih
                A1708 820-00840 no power
                by nassih
                hello everybody my macbook a1708 is giving me some issues:
                no power and no amp consumption i have replaced c7078 was shorted to ground. voltage checked :
                ppbus_g3h=0.3
                ppdcin_g3h_chr_r=5.1v
                ppvin_g3h_p3v3 g3h=3.8v
                pm_en_p3v3_g3h_r=4.6v
                pp3v3_g3h_vr=2.2v (required 3.3v)
                pp3v3_g3h=2.2v (required 3.3v)
                no short to ground
                tanks
                01-29-2023, 01:15 PM
              • willumpie82
                A1708 020-00840 liquid damage, no power
                by willumpie82
                Hi All,
                I'm working on a case for data recovery of an A1708 board 820-00840
                when I received the board it was doing absolutely nothing. I took some pictures of the corrosion and ultrasonically cleaned the board. this revealed some problem areas.
                no power via USB-C (stays at 5v 0mA, other port 5v 50mA)
                PP3V3_GH, repaired the circuit and now 3,4v present
                both CD3215 replaced, PPDCIN_3GH present at Q7030 (usb 5v 10mA)
                I did not trust the U7000 (weird impedance at Aux_det) so replaced it
                now Aux det is 1,2v and R7015,...
                07-18-2020, 06:53 AM
