MacBook Pro 820-3476 random screen fickering
  • Francisco.s
    • 686
    • Spain
    Hi, this MacBook Pro with 820-3476 motherboard presents random flickering.
    It does even at boot screen pressing alt key at boot time.
    I have tested a good screen, but random flickering is still present.
    There are no signs of water damaged.
    I have checked all main voltages with a digital scope, but it didn't catch anything.
    Any ideas about it?
    Thanks.
  • Francisco.s
    • 686
    • Spain
    Re: MacBook Pro 820-3476 random screen fickering
    I forgot to mention that image is ok via hdmi.
    It starts at the very beginning, and not increase with temperature, and it's the same whith battery or charger. (also only screen and motherboard connected)
    • mon2
      • 14369
      Sounds like the lcd backlight is flaking out on you?
      Check for the backlight rail voltage during these fluctuations. Also see if the enable to the backlight is stable during the same event.
      • piernov
        • Jan 2016
        • 4437
        • France
        We have no idea what you mean by flickering. Post video.
        • Francisco.s
          • 686
          • Spain
          Hi moon, yes it is a real nightmare.
          I have tested the following voltage/signals and found no fluctuations:
          EDP_BKLT_PWM
          PPVOUT_S0_LCDBKLT
          PP5VR3V3_SW_LCD
          I have to test more signals on J8300, (edp connector) but it is difficult to test due to the random character of the issue.
          • Francisco.s
            • 686
            • Spain
            I will make a video and post the link.
            Sometimes the brightness of the screen fluctuates, and sometimes seems to lose vertical an horizontal sync.
            It is difficult to explain, but there are no pixelation or blur.
            • Francisco.s
              • 686
              • Spain
              Unfortunately the laptop has been returned to the customer without repair.
              I wanted to do some more tests and a video, but customer wants a quick solution.
              Anyway thanks a lot for your help.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3609
                • slovakia
                did u try to resolder HDMI pins?
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3609
                  • slovakia
                  forgot about my post
                  • mon2
                    • 14369
                    The following brief video from Louis may be worth a quick view to see if you have a related case:
                    https://youtu.be/JGNOGHXhpbQ?t=2659
                    He chats about screen flickering.
                    • Francisco.s
                      • 686
                      • Spain
                      Hi mon2, this video from Louis is about backlight problem.
                      Did you copy the correct link or is there an error?
                      The title of the video I watched is:
                      820-2915 no backlight, 29v - how are we 29v w/ no brightness & how do we fix it?
                      i'm always learning from Louis videos, so is not a wasted time.
                      Thanks for your help.
                      • mon2
                        • 14369
                        Watch the video from the link that was shared. He discusses other reasons for the flickering.
                        • Ryan.man
                          by Ryan.man
                          02-04-2025, 12:23 PM
                        • reformatt
                          by reformatt
                          07-31-2025, 08:37 PM
                        • MagJ_
                          MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
                          by MagJ_
                          Hello Everybody,
                          I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
                          10-09-2024, 02:51 PM
                        • sofles
                          Macbook Pro 16" A2141 screen artefacts, kernel panic
                          by sofles
                          Hi there.
                          I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                          I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                          Now situation looks like this, If...
                          02-05-2025, 05:05 AM
                        • ahoonid
                          MacBook A1990 vertical stripes on external screen
                          by ahoonid
                          Hey everyone,
                          I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                          The board is neat. Not opened before for sure. Just a little dust, nothing more.
                          Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                          06-20-2025, 08:54 AM
