hp pav 15-r no 3.33v on power switch bouton
  • YOUCEF4787
    • May 2014
    • 22
    • ALGERIA
    hi
    i have laptop hp pav 15-r
    hp pavilion 15-e077ek
    motherboard: da0r62mb6e0 rev:e
    no power up
    all volts are ok only power boton have no 3.33v volte i change it but the same.
    i replace the risistor r880 but the same.
    every think is discribed in picturs attached
    any solutions pls.
    • 21852
    Re: hp pav 15-r no 3.33v on power switch bouton
    Post the full laptop model number, motherboard part number and a link to the schematic if its already posted in the schematic requests forum
    • YOUCEF4787
      • May 2014
      • 22
      • ALGERIA
      every thing is ok
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Do you have voltage on SDA/SCL pin??
        • Powderfanupnorf
          Dell AL440LX power on switch circuit help required
          by Powderfanupnorf
          Hi Everyone. First official post so fingers crossed I conform and also manage to get photos to work.
          So I am requesting some help from anyone who happens to have one of these motherboards to hand and perhaps a multimeter.
          My board has a single row of header pins for all the front panel stuff (have seen others where they are grouped together differently so thats no help) and the two pins for the power on switch had been previously repaired and I am trying to make a better repair. There looks to be pad and trace damage and im happy to relocate the header pin/pins to...
          06-24-2024, 01:24 PM
        • grimacelord
          NEC TurboExpress On/Off Power Switch Replacement Help
          by grimacelord
          I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
          I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
          I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
          11-09-2023, 09:49 AM
          09-06-2024, 05:59 AM
        • shovenose
          Ubiquiti Unifi PoE Switch US-8-150W Power Supply Failure
          by shovenose
          Got this one for free because, well, it no worky.
          A little research and there are tons of complaints all over forums/the internet about premature failure of these switches. The observation everyone makes about these is "they run hot" and failure occurring as soon as 13 months, right out of warranty, of course.
          Upon removal of the cover I found a G0398-15011480A power supply that, when plugged in, was making a constant ticking noise. Multimeter confirmed the PSU was the issue. Output was cycling between 0 and about 20V. With output disconnected it sat around...
          08-11-2021, 01:26 PM
