820-00840 dead 19.7v and 0.01A
  • kingskie
    • Oct 2014
    • 249
    • indonesia
    i am working on macbook pro A1708 820-00840-A.
    no history..customer just brought and say cannot turn on.
    i plugged usb c amp meter and got 19.7v and 0.01A
    check PPBUS_G3H 0.425V..check PPBUS_G3H but no short...but when measure for resistance i got 110 ohm on PPBUS_G3H..check for other rail but no short. can someone help?
  • mon2
    • Dec 2019
    • 14146
    Re: 820-00840 dead 19.7v and 0.01A
    Hi. Do not have a schematic in front of me at this time but often the PPBUS_g3h regulator is powered from a dual common-cathode diode. Search for it and post the voltage on each of the pins.
    One pin is from the 20v adapter.
    One pin will be from the battery.
    Output pin will be to this regulator. This output pin must be close to the input rail value.
    Post the measurements.
    • kingskie
      • Oct 2014
      • 249
      • indonesia
      hi mon2,
      here i attached the schematic
      • mon2
        • Dec 2019
        • 14146
        Thanks. Post the voltages on each pin of D6905.
        My bad, confirm that the 3v42 voltage is stable.
        Then measure the voltage on both sides of F7000 fuse (ppbus_g3h). Still low voltage?
        If yes, power down and remove F7000. Do NOT bypass it.
        Just want to confirm that the power switching circuit is working to produce the ppbus_g3h rail ok.
        What is the voltage if this rail without F7000? You will be measuring the voltage directly at pin #1 of F7000 pad.
        • kingskie
          • Oct 2014
          • 249
          • indonesia
          thanks. Post the voltages on each pin of d6905.
          Then measure the voltage on both sides of f7000 fuse (ppbus_g3h). Still low voltage?
          If yes, power down and remove f7000. Do not bypass it.
          What is the voltage if this rail without f7000? You will be measuring the voltage directly at pin #1 of f7000 pad.
          d6905:
          Pin 1 0.43v
          pin 2 20.1 v
          pin 3 19.8v
          pp3v3_g3h 3.4v
          took off f7000
          pin ppbusg3h 0.4v
          pin ppvbat_g3h_chrg_reg 13v
          • mon2
            • Dec 2019
            • 14146
            Post the voltage readings on each pin of Q7030. Interested to know the voltage of SOURCE, DRAIN and GATE. Note there are 2 mosfets inside each.
            Do the same for Q7040.
            • mon2
              • Dec 2019
              • 14146
              Adding to your list...
              with F7000 removed, meter in resistance mode, no power to the logic board,
              check & post the resistance to ground for the F7000 pad # 1
              check & post the resistance to ground for the F7000 pad # 2
              This is to allow us to check which side of the fuse is causing this heavy load.
              • kingskie
                • Oct 2014
                • 249
                • indonesia
                resistance to ground for the F7000 pad # 1 OL
                resistance to ground for the F7000 pad # 2 115 ohm
                • kingskie
                  • Oct 2014
                  • 249
                  • indonesia
                  these measurements without remove the mosfet
                  Q7030
                  PIN 1-3 ------20V
                  PIN 4 ----------0V
                  PIN 5-6 -------GND
                  PIN 7-10 ------0V
                  PIN 11 --------0V
                  PIN 12 --------0V
                  PIN 13 ------20V
                  PIN 14 -------GND
                  Q7040
                  PIN 1-3 --------0.4V
                  PIN 4 -----------0V
                  PIN 5-6 --------GND
                  PIN 7-10 -------0V
                  PIN 11 ---------0V
                  PIN 12 ---------0V
                  PIN 13 ---------0.4V
                  PIN 14 ---------GND
                  • mon2
                    • Dec 2019
                    • 14146
                    Power down. Meter in resistance mode.
                    Please post the resistance readings for these same mosfets:
                    source to drain
                    source to gate
                    gate to drain
                    Review the resistance chart from this website for guidance:
                    http://electronicsbeliever.com/how-t...-is-defective/
                    • kingskie
                      • Oct 2014
                      • 249
                      • indonesia
                      source to drain
                      source to gate
                      gate to drain
                      i assume the mosfet is broken and replace it but still low on ppbus...could it be U7000 ?
                      • kingskie
                        • Oct 2014
                        • 249
                        • indonesia
                        update for this problem, i replaced U7000 but still no luck..checked again and found out that PP3V3_TBT_X_F is shorted but i check the others PP3V3 line are not shorted..
                        any suggestion?
                        • kingskie
                          • Oct 2014
                          • 249
                          • indonesia
                          update.. i found the short..it is C2977. but i lost some components when i open the shield. it is D3411, C3408 and D3403..is it ok if i dont replace the missing components regarding is is a supported components for usb C
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • disorder
                            ps5 edm-033 dead after hdmi/usb ports destroyed
                            by disorder
                            hello guys,
                            i need help to repair a edm-033 ps2
                            history : as always hdmi port and usb ports destroyed after unplugged
                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                            so i changed it
                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                            i don't see any projection of liquid metal on pcb.
                            01-14-2025, 12:48 PM
                          • Beton
                            Finding a dead short component
                            by Beton
                            Hi guys!
                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                            I have a bench PSU and if I try to inject voltage the voltage...
                            12-10-2021, 01:05 PM
                          • zunasthegreat
                            Chieftec GPS-450-AA with dead 20N60C3
                            by zunasthegreat
                            Hello everyone hope all doing well!
                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                            09-01-2024, 07:12 PM
                          • FiguringITout
                            MSI Raider GE75 - Not posting, probable dead CPU
                            by FiguringITout
                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                            07-25-2024, 07:27 AM
