Shorted Cpu? Hp Faroe_Dis_X32
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by reessiHello:
I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
I started on the ACER:
Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap... -
by YanlebHi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
D608, good
D618 RF101L4S, good (See warning 1 below)
D619 RF101L4S, good (See warning 1 below)
D865 RF101L4S, shorted (See warning 1 below)
IC464 Inverter HA MC74HC1G14, shorted...03-09-2020, 12:00 AM -
by BalkanBoyHi,
today I got Razer Blade 14, Ryzen 9 6900HX and RTX 3070Ti.
Laptop was completely dead. I found shorted CPU VRM mosfet, shorted 19V mosfet and blown battery fuse.
I replaced it all, but still on CPU coil where mosfet was shorted I got very low resistance, near 0 ohms. On other CPU coils I got around 3 ohms.
Laptop now raises voltage on whole board, but still nothing comes on the screen. CPU gets 0.7V on all coils except the shorted one. CPU gets only slightly hot, below 40 C.
I removed coil and injected 0.7V, it draw around...09-27-2024, 12:44 PM -
by barry101Hi, Would appreciate some help.
I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
Get charger light but no fan spin or chime. No liquid damage.
Found PPBUS and VCORE both shorted to ground. Other rails were ok.
Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my... - Loading...
