Dell Precision 7510 charge battery and left side board problem.
  • mon2
    • 14691
    Re: Dell Precision 7510 charge battery and left side board problem.
    Also please confirm the MDV1524 is correct replacement for AON7752
    Yes, the MDV1524 looks to be compatible. Same footprint, pinout and heavier current support. Vgs is very similar as well.
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      #42
      Originally posted by Andreasbest
      So PC114 was indeed grounded
      Replaced PQ101
      Now i have a problem with PQ103 traces on MB, they are all kinda shorted between them (~20Ω)
      PQ103 is not soldered, i just measure the traces on it's position, is this normal?
      Thank you for the confirmation.
      My main problem is with PQ103, i removed it because was burnt too but all traces seems shortcircuit to each other, only 20Ω resistance.
      Is this normal?
      • mon2
        • 14691
        Hi. Can you confirm that PQ103 is as per attached schematic ?
        You have removed this part and are measuring 20 ohms between the pads for
        GATE & SOURCE ?
        GATE & DRAIN ?
        SOURCE & DRAIN ?
        If yes, lift up one leg on coil PL102 and measure again.
        Post where exactly you are measuring the 20 ohms.
        • Andreasbest
          • Aug 2014
          • 1196
          • Hellas ( Greece )
          #44
          GATE & SOURCE ?
          GATE & DRAIN ?
          SOURCE & DRAIN ?
          Hello!
          I removed PQ103 because DRAIN was shorted with GATE, then i notice that it's traces on MB are shorted/20Ω too.
          I measured DRAIN with SOURCE, DRAIN with GATE and also DRAIN with GROUND, all of them are 20Ω.
          Now with PL1L102 lifted i get:
          DRAIN with SOURCE 0.8ΜΩ
          DRAIN with GATE 0.8ΜΩ
          DRAIN with GROUND 7.5MΩ
          all measurements with BLACK probe on drain.
          • mon2
            • 14691
            With PL102 having 1 leg lifted, what is the resistance between pin # 2 (red meter lead) of PL102 pad and ground (BLACK meter lead) ?
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              #46
              Goodmorning!
              ~20Ω (18,9Ω precisely)
              • Andreasbest
                • Aug 2014
                • 1196
                • Hellas ( Greece )
                #47
                Bump
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  #48
                  PL102 lifted and short circuit is gone, no more 20Ω but several kΩ instead.
                  Short still remains on lifted coil (red arrow short, green arrow no longer short)
                  • Spider1211
                    • Oct 2019
                    • 532
                    • Mauritius
                    #49
                    Remove PL102 completely. Which side is which? Green arrow is pin 1 or 2 (referring to schematic).
                    Is PJP102 and PJP103 present?
                      • 22021
                      PJP102 and PJP103 are after pin 2 of PL102. +5VALWP -> +5VALW
                      • Andreasbest
                        • Aug 2014
                        • 1196
                        • Hellas ( Greece )
                        #51
                        Yes, side connected to PJP102 has 20Ω, the other is on ~300KΩ (with PL102 removed)
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          #52
                          What I meant was, is PJP102/3 solder or continuous copper track? If it is solder type, i'd suggest resoldering PL102 and removing the jumper. That way you can eliminate the chip itself as a potential cause and you could also test if the chip is working properly by powering the board (provided ofcourse that you took care of the shorted mosfets).
                          • Andreasbest
                            • Aug 2014
                            • 1196
                            • Hellas ( Greece )
                            #53
                            PJP102 and 103 are both solder jumpered.
                            I'll remove jumper solder from 102 on Monday that i'll return to bench and reply.
                            Also both burnt mosfet are replaced.
                            After pjp102 opening can i try to power on the mb provided the 20Ω resistance is limited to the one pin of pjp102?
                            • Spider1211
                              • Oct 2019
                              • 532
                              • Mauritius
                              #54
                              Just to confirm, do you still get 20Ohm after removing daughter boards? If you havent tried, try that first.
                              You need to remove solder on both pjp102 and pjp103. After that measure resistance again, the pjp pad connecting to PL102 should be high resistance and the other pad should still be 20Ohms.
                              If thats the case, then yes you can apply power and try turning on the laptop. You should read 5V on PL102. Otherwise report back on the resistance values you get.
                              • Andreasbest
                                • Aug 2014
                                • 1196
                                • Hellas ( Greece )
                                #55
                                Yes, bot daughterboards are disconnected, only GPU is still attached.
                                Ok will do this first thing Monday morning and report back.
                                • Andreasbest
                                  • Aug 2014
                                  • 1196
                                  • Hellas ( Greece )
                                  #56
                                  Goodmorning, back to the bench again.
                                  I work around PL102 and got some strange readings.
                                  With PL102 unsoldered i have 20Ω in upper pin (the one connected directly to pjp 102 and pjp103) and the same time on both pins of both pjp jumpers that i desolder!
                                  With a few words, everything above PL102 upper pin is 20Ω to GND.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1196
                                    • Hellas ( Greece )
                                    #57
                                    bump
                                    • Spider1211
                                      • Oct 2019
                                      • 532
                                      • Mauritius
                                      #58
                                      Try removing PU101 to and measure resistance again (DO NOT power motherboard with this chip removed). If its still same, try removing PU1001 (CD3301) since you had an almost similar reading last time. Report back after trying.
                                      Aalso measure resistance on all coils and post your resistance reading.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1196
                                        • Hellas ( Greece )
                                        #59
                                        Should i remove PU101 first and then check resistance on coils OR coils first?
                                        • Spider1211
                                          • Oct 2019
                                          • 532
                                          • Mauritius
                                          #60
                                          Since you mentioned desoldering PJP102/3 doesn't change anything I'd start with pu101 first.
                                          • Stephen
                                            A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
                                            by Stephen
                                            Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
                                            05-29-2025, 10:35 AM
                                          • ravi_1617
                                            HCL Laptop SCREEN SIZE SHRINK LEFT SIDE AROUND 2 INCHES
                                            by ravi_1617
                                            Hello to all ,
                                            I have this HCL ME LAPTOP K 41 ,screen image is shrieked clock /speaker left side approx. 2 inches .Its 14.1 LCD SCREEN. I have replaced lcd screen ,found no difference
                                            Its blank that area blank and bottom of Task bar is rolled at bottom displaying top portion image . In bios /setup also getting same problem
                                            on external VGA port image is perfect /normal , Attached image...
                                            07-25-2025, 12:07 AM
                                            DELL Precision 3630 Precision i7-9700 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 3630 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 3630 boardview and Precision 3630 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                            09-12-2024, 03:44 PM
                                            DELL Precision 5820 Precision 5000 W-2235 Specification for Upgrade or Repair
                                            This specification for the DELL Precision 5820 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision 5820 boardview and Precision 5820 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
