HP DAY11AMB6E0 REV E no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day board has no power
    checking all coil resistance no problem
    I already change the CHARGER IC PU1
    PU1 READINGS
    #! ACN - 19V
    #2 ACP - 19V
    #3 CMSRC - 19V
    #4 ACDRV - 25V
    #5 ACPRES- 2.9V
    #6 ACDET - 2.7V
    #7 IOUT - 0V
    #8 BQDATA - 3.3V
    #9 BQCLK - 3,3V
    #10 ILIM -1.0V
    #11 BATDRV - 2.9V
    #12 BQSRN - 2.9V
    #13 BQSRP - 2.9V
    #14 GND - 0V
    #15 LODRV - 0V
    #16 REGN6V - 6V
    #17 BTST 5.9V
    # 18 HIDRV - 2.9V
    #19 PHASE 2.9V going up
    #20 BQVCC - 19V
    I dont have +3VALW AND +5VALW
    PU11
    #1 EN1 0V
    #2 PGOOD - 0V
    #3 FB -0V
    #4 VOUT - 0V
    #5 VCC -3.3V
    #6 BST -3.3V
    #7 LDO - 2.9V
    #8 VIN - 19V
    #9 GND - 0V
    #10 SW -0V
    PL21 ressitance to gnd 5.9 kohms
    PU12
    #1 EN1 0V
    #2 PGOOD - 0V
    #3 FB -0V
    #4 VOUT - 0V
    #5 VCC -3.4V
    #6 BST -2.9VV
    #7 LDO - 5.1V
    #8 VIN - 19V
    #9 GND - 0V
    #10 SW -0V
    PL20 43 KILOHMS
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: HP DAY11AMB6E0 REV E no power
    hHere is the schematic
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Dc Jack light glowing?? Bios flashed including KBC?? Both PU11 & PU12 are enabled by S5_ON which comes from SIO. So you need to check the requirement of KBC are fulfilled or not. Another sore point on this mb is RTC Section. Do check that as well.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        DC jack not glowing
        u11
        pltrst # - 0v
        RSMRST# 0V
        S5_ON - 0V
        EC_PWROK - 0V
        ACIN - 2.9V
        +3VPCU - 3.3V
        • piernov
          • Jan 2016
          • 4435
          • France
          Power button must be triggered to get ALW power rails on this board IIRC.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If DC jack is not glowing, you need to check adapter id as well+3V LDO needs to be checked.
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              If I Press the power it only blinks 5 times then no light taking 3miliamp
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                Originally posted by piernov
                power button must be triggered to get alw power rails on this board iirc.
                iirc?
                  • 20952
                  Originally posted by kalilinux25
                  iirc?
                  if i remember correctly
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    ahw I thought RTC section
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      It means adapter is not detecting. Check AD_ID and related on sio.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        checking the adapter Type check circuit
                        READINGS
                        D7 pin 1 0v pin 2 0v
                        D8 pin 1 3.3v pin 2 0v
                        R298 0V all sides value 99ohms
                        R304 12.1K value ok
                        r294 9.9kilo
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          AD_ID is missing. Check AC_IN reaching sio or not.
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            PIN 97 OF SIO
                            ACIN has 2.9v
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              What about AD_AIR?? It could be simple bios issue as well-So flash both main and kbc before diagnosing further.
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                Ill try it tommorow sir to flash ec and bios chip
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  I already tried the bios but still no power light blinks if i press power taking 3 milliamp , I can programm the ec bin because it has no power
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    You can apply 3v on VCC pin of SIO and program it.
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      Which pin sir?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Which pin sir?
                                        Pin11 of ITE8987 connected to C350
                                        • totof
                                          HP Pavilion 15-p294nf no power MB DAY11AMB6E0 REV E
                                          by totof
                                          Hello
                                          I need help to repair my PC.
                                          My PC HP does not start, no light on DC Jack LED, no power consomption (only 1,3 mA).
                                          I don't have 3.3V.
                                          On PU11 :
                                          #1 EN1 0,5V
                                          #2 PGOOD - 0V
                                          #3 FB -0V
                                          #4 VOUT - 0V
                                          #5 VCC -0.5V
                                          #6 BST -0.0V
                                          #7 LDO - 5.36V
                                          #8 VIN - 19V
                                          #9 GND - 0V
                                          #10 SW -0V
                                          EN2 is too low to active the chip !!!
                                          #EN2 is connected to SIO S5_ON so S5_ON is bad.
                                          On U11 (SIO) :
                                          #AD_AIR = 0,93V
                                          #AD_TYPE = 0,74V
                                          #S5_ON = 0,5V
                                          04-02-2022, 02:18 PM
                                        • saronno
                                          1050ti asus cerberous: 1.8v present, 1.8v pgood missing ..
                                          by saronno
                                          I have this weird case where 1.8v is presente but 1.8v pgood is missing preventing the card to post.
                                          The card sometimes post, in particular when mb and gpu are cold e without voltage for long time. If it post, then no problem, it loads the drivers and everything works fine.
                                          the chip who provide 1.8v is an nb671lb.
                                          have you ever had an issue like that on a 1050ti or any other pascal gpu?
                                          TIA
                                          05-07-2023, 05:15 AM
                                        • madan1
                                          Mackie Th15 SMPS low Vout
                                          by madan1
                                          I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
                                          It is basically a smps with amp and some dsp.
                                          The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
                                          Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
                                          By the way, the ferrite core of L10 is broken,...
                                          02-16-2025, 04:15 PM
                                        • MIDOX
                                          BIOS dump FOR DAY11AMB6E0 REV E
                                          by MIDOX
                                          HI
                                          I'm Locking for clean my old BIOS dump FOR DAY11AMB6E0 REV E QUANTA Y11A
                                          Chip: ITE8987E
                                          BID 02292
                                          I download many bios dump but is not working....
                                          Please help me...
                                          01-06-2023, 05:12 PM
                                        • electrocute
                                          Lenovo Ideapad 330S-14IKB Not Powering On
                                          by electrocute
                                          Lenovo Ideapad 330S-14IKB Model: 81F4
                                          Motherboard: 330S_KBL_MB_V09 Rev: MP (PN: 431204237090) (5B20S69494)
                                          Has been working till now for two months after cleaning water damage.
                                          Problem: does not power on. No consumption.
                                          19-20V present.
                                          3.3V and 5V not present.
                                          No power around EC.
                                          Missing ILIM, ACOK... on the charger. No EN nor PGOOD on the 3/5V power supplies.
                                          Charger BQ24780SRUYT (U5901):
                                          <1>ACN: 19.78V
                                          <2>ACP: 19.78V
                                          <3>CMSRC: 19.68V
                                          <4>ACDRV: 24.6V
                                          <5>ACOK: 0.01V...
                                          09-24-2021, 02:16 PM
