HP DAY11AMB6E0 REV E no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day board has no power
    checking all coil resistance no problem
    I already change the CHARGER IC PU1
    PU1 READINGS
    #! ACN - 19V
    #2 ACP - 19V
    #3 CMSRC - 19V
    #4 ACDRV - 25V
    #5 ACPRES- 2.9V
    #6 ACDET - 2.7V
    #7 IOUT - 0V
    #8 BQDATA - 3.3V
    #9 BQCLK - 3,3V
    #10 ILIM -1.0V
    #11 BATDRV - 2.9V
    #12 BQSRN - 2.9V
    #13 BQSRP - 2.9V
    #14 GND - 0V
    #15 LODRV - 0V
    #16 REGN6V - 6V
    #17 BTST 5.9V
    # 18 HIDRV - 2.9V
    #19 PHASE 2.9V going up
    #20 BQVCC - 19V
    I dont have +3VALW AND +5VALW
    PU11
    #1 EN1 0V
    #2 PGOOD - 0V
    #3 FB -0V
    #4 VOUT - 0V
    #5 VCC -3.3V
    #6 BST -3.3V
    #7 LDO - 2.9V
    #8 VIN - 19V
    #9 GND - 0V
    #10 SW -0V
    PL21 ressitance to gnd 5.9 kohms
    PU12
    #1 EN1 0V
    #2 PGOOD - 0V
    #3 FB -0V
    #4 VOUT - 0V
    #5 VCC -3.4V
    #6 BST -2.9VV
    #7 LDO - 5.1V
    #8 VIN - 19V
    #9 GND - 0V
    #10 SW -0V
    PL20 43 KILOHMS
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: HP DAY11AMB6E0 REV E no power
    hHere is the schematic
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Dc Jack light glowing?? Bios flashed including KBC?? Both PU11 & PU12 are enabled by S5_ON which comes from SIO. So you need to check the requirement of KBC are fulfilled or not. Another sore point on this mb is RTC Section. Do check that as well.
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        DC jack not glowing
        u11
        pltrst # - 0v
        RSMRST# 0V
        S5_ON - 0V
        EC_PWROK - 0V
        ACIN - 2.9V
        +3VPCU - 3.3V
        • piernov
          • Jan 2016
          • 4439
          • France
          Power button must be triggered to get ALW power rails on this board IIRC.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            If DC jack is not glowing, you need to check adapter id as well+3V LDO needs to be checked.
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              If I Press the power it only blinks 5 times then no light taking 3miliamp
              • kalilinux25
                • Mar 2018
                • 2089
                • ZAMBOANGA SIBUGAY
                Originally posted by piernov
                power button must be triggered to get alw power rails on this board iirc.
                iirc?
                  • 21932
                  Originally posted by kalilinux25
                  iirc?
                  if i remember correctly
                  • kalilinux25
                    • Mar 2018
                    • 2089
                    • ZAMBOANGA SIBUGAY
                    ahw I thought RTC section
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      It means adapter is not detecting. Check AD_ID and related on sio.
                      • kalilinux25
                        • Mar 2018
                        • 2089
                        • ZAMBOANGA SIBUGAY
                        checking the adapter Type check circuit
                        READINGS
                        D7 pin 1 0v pin 2 0v
                        D8 pin 1 3.3v pin 2 0v
                        R298 0V all sides value 99ohms
                        R304 12.1K value ok
                        r294 9.9kilo
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          AD_ID is missing. Check AC_IN reaching sio or not.
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            PIN 97 OF SIO
                            ACIN has 2.9v
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              What about AD_AIR?? It could be simple bios issue as well-So flash both main and kbc before diagnosing further.
                              • kalilinux25
                                • Mar 2018
                                • 2089
                                • ZAMBOANGA SIBUGAY
                                Ill try it tommorow sir to flash ec and bios chip
                                • kalilinux25
                                  • Mar 2018
                                  • 2089
                                  • ZAMBOANGA SIBUGAY
                                  I already tried the bios but still no power light blinks if i press power taking 3 milliamp , I can programm the ec bin because it has no power
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    You can apply 3v on VCC pin of SIO and program it.
                                    • kalilinux25
                                      • Mar 2018
                                      • 2089
                                      • ZAMBOANGA SIBUGAY
                                      Which pin sir?
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        Which pin sir?
                                        Pin11 of ITE8987 connected to C350
