HP 14 Caps lock blink 1 time
  • computeka
    • Apr 2021
    • 31
    • colombia
    DA0U93MB6D2 Rev.D
    hello people !, thanks for attending me, I have the problem with an HP 14 that turns on but does not give video and the caps lock blinks 1 only time every 3 seconds, any idea what it could be ?.
  • mon2
    • 14664
    Re: HP 14 Caps lock blink 1 time
    hi.
    https://h30434.www3.hp.com/t5/Notebo...t%20functional.
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      1. Check for short on the coils.
      2. Measure voltage on the coils when turned on.
      3. Check your RAM slots and make sure there is no debris. Also check the solder joints.
      Report back on the above when done.
      • battery.12v
        LA-B972P Caps lock Blink one Time
        by battery.12v
        15-r259ne LA-B972P came no display, caps lock blink one time (CPU not Functional)
        CPUcore is present 1.73V, all other voltages are present also 5v,3.3., 1.35v, 1.05v , gpu volt
        any guidance ? flashed too many bios files but no luck
        08-13-2021, 12:08 PM
      • AdrenalinTL
        Caps and num lock blink 4 times
        by AdrenalinTL
        I am sitting with a very similar issue.
        Basically, had a probook that worked, gave it to someone, they returned it DOA. what the heck happened, I have no idea.
        Caps and num lock blink 4 times, as per HP, thats a board failure. I am very new to this, so perhaps I should be posting a new thread?
        Anyway, I resoldered the bios chip on after trying EVERYTHING else including reseating ram, cpu etc.
        Multimeter shows 19.5V on power, so I presume thats correct. Fan spins, no display. No post. Bios chip looks good from what I can tell just not sure how...
        04-09-2024, 10:34 AM
      • dclass-pro
        Hp DAOP5FMB6A0 blink caps/lock problem
        by dclass-pro
        Hi guys, I have an HP model 15s-eq1040nl main DAOP5FMB6A0 REV:A with a caps/lock 5 long 3 short led flashing problem, I tried to remove the battery and program a new bios and when I restarted it immediately worked correctly, the pc turned on and loaded the operating system.
        As soon as I turned off the pc and connected the battery, the problem reappeared... caps/lock 5 long 3 short led flashing again!
        the battery was dead, i charged it and it works fine, but the pc won't turn on again.
        What do you recommend me? Do I have to redo the bios or is there anything else to check?...
        05-08-2023, 12:46 PM
      • Curtissimo
        HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
        by Curtissimo
        Hi everyone.
        I have a HP Elitebook 850 G8.
        Serial: 5CG2324XM0
        ProdID 6L8D5EC#ABA
        It has a Winbond W25Q256JVEN Chip.
        I need to remove BIOS Password.
        I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
        Attached my dump.
        I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
        I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
        What I did:...
        08-26-2025, 04:42 AM
      • Kiwi Viking
        HP Elitebook 855 G8 all of a sudden does not power on. 7 flashes of Caps lock and Number lock prod ID 4X5S2PA#ABG
        by Kiwi Viking
        HP Elitebook 855 G8
        Product ID:4X5S2PA#ABG
        Motherboard M53301-601.
        Hi Gurus, I am wondering if someone might be able to help. I purchased recently this used computer that otherwise looks in mint condition. I worked for 1 week, until one morning I shut down the computer using the power off commands in windows. There was no warranty. This was purchased for my teenager for use at school.
        When I went to start the computer up in the afternoon, all the keys lit, but the computer didn't POST. Then the next thing I tried (pressing the power button) resulted in only the...
        03-01-2025, 01:05 AM
