Onboard RAM question.
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    Hey guys, say I have a motherboard with onboard RAM and 1 out of 4 memory chips failed. Will the motherboard work if the faulty memory is removed or does it need to be replaced (otherwise it'll throw errors since its expecting to see a certain amount of memory)? Is it something that is manufacturer dependent?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8688
    Re: Onboard RAM question.
    manufacturer/model dependent.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      If you remain only 1 chip,wont work for sure.
      • Spider1211
        • Oct 2019
        • 532
        • Mauritius
        Ah ok, thank you guys. Guess I need to find a donor board with the same RAM chips then.
        Is it possible to mix RAM chips? Provided they are equivalent to each other ofcourse.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          I'll prefer to replace all four chips in one go with same specs to avoid wasting time.
          • ChaosLegionnaire
            by ChaosLegionnaire
            09-13-2022, 09:02 AM
          • brotank
            Lenovo C861 Ryzen 5 disable 4GB samsung onboard ram
            by brotank
            I quiet struggling with board lenovo c681 to disable 4gb samsung onboard ram because they're faulty, I followed the instruction on the schematic to disable them with resistor codes but still not detecting the ram on the slot.
            can someone disable onboard ram from my dumped bios, please 🙏
            I tried the other bios on this forum with disabled onboard ram, but no success
            my final try is to find someone that can help disable onboard ram in my dumped bios attached in this post.
            after that I officially give up 😂
            thanks for awesome jobs 😊...
            03-16-2025, 12:51 PM
          • b-slayer
            Acer A317-53 need help to disable faulty onboard ram
            by b-slayer
            Hello.
            I have an Acer Aspire A317-53 laptop with faulty onboard ram modules, after online searches, I have only found two options to get it working :
            - first one is to modify le bios to disable the onboard ram.
            - second one is to disable the onboard ram by desoldering some components on the mainboard.
            so after some hours google-ing, i have to give-up the modified bios option, main reason is I couldn't find anywhere a such modified Bios, alternate reason is that if windows update makes a bios update, the problem is always here...
            so i found that my motherboard...
            10-12-2024, 03:46 AM
          • xloomx
            X512DK MAIN BOARD REV. 2.1 Disable Onboard RAM
            by xloomx
            Asus F512D, motherboard X512DK MAIN BOARD REV. 2.1 Hynix 4GB OnBoard, (ID0=0, ID1=0, ID2=1)
            In this case to disable onboard ram, Take out R0916 and place a 10K Resistor on R0913.
            The configuration would be for N/A:N/A , ID0=1, ID1=0, ID2=1. (Working for me with Hynix 4gb OnBoard Memory, in this case, do not touch other resistors)
            Images Attached...
            01-28-2025, 10:14 AM
          • chappers
            Nvidia MATS help please - 33 errors on two cards?
            by chappers
            I'm new to MATS and can only use it after watching a Youtube video, downloading the one he linked to (version 400.184) and running it without changing anything. I have no great understanding of it.
            I have 3 graphics cards in the house.
            My son's - Palit GTX 1080 used for 3D games constantly.
            Mine - Nvidia GTX 1080 not used for 3D games, just basic stuff.
            Inno3D RTX 2080 I bought faulty hoping to repair for my son's PC.
            Running MATS on my son's GTX 1080 gives a pass with no errors.
            Running MATS on my GTX 1080 gives...
            08-09-2023, 01:28 PM
