A1708 820-00875 battery drain in stby after SSD replacement by original one
  • Beeldbuisje
    • Jul 2020
    • 57
    • Belgium
    the A1708 is famous for battery drain in stby if a non OEM Apple SSD is installed.
    Got this machine with a defective SSD, installed an adaptor + 2242 nvme for testing. Works fine, but battery drain in standby; normal behavior.
    I ordered a used, but exactly the same SSD (the same Apple part number) second hand (from a macbook with screen issues). Works fine, laptop lasts 10H on one battery charge.
    Put them in deepstandby, confirmed by the pmset logs, and drains his battery in less than a week. Better as with an adaptor + nvme, but not the 30 days it should last on.
    Battery is new.
    Could it be possible this ssd must be "paired" or something with the motherboard?
  • Prott
    macbook A1708 - BMU replacement
    by Prott
    just a quick sanity check question before I blow myself up.
    Is it ok to transplant a working BMU from a dead A1708 battery to a working battery with a dead (not recognized) BMU? Assuming I will be very careful not to short anything out while doing it.
    I am just worried the BMU retains some battery specific data that will either kill the new battery or make it behave like an old one (the amount of charging cycles, etc.).
    02-09-2023, 05:42 AM
  • tofik
    MOSFET equivalent K8A60DA
    by tofik
    Hello guys,
    I have a shorted MOSFET K8A60DA with the following characteristics:
    Type Designator: TK8A60DA
    Marking Code: K8A60DA
    Type of Transistor: MOSFET
    Type of Control Channel: N -Channel
    Maximum Power Dissipation (Pd): 45 W
    Maximum Drain-Source Voltage |Vds|: 600 V
    Maximum Gate-Source Voltage |Vgs|: 30 V
    Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
    Maximum Drain Current |Id|: 7.5 A
    Maximum Junction Temperature (Tj): 150 °C
    Total Gate Charge (Qg): 20 nC
    Rise Time (tr): 25 nS
    Drain-Source
    07-19-2023, 05:18 AM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • the_rem
    Unknown transformer : how to find a good replacement part ?
    by the_rem
    Hello guys,
    I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
    I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
    04-23-2025, 01:48 AM
  • ezenia
    PS4 controller left stick potentiometer replacement issue
    by ezenia
    Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
    So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
    I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
    09-30-2023, 02:19 PM
