help me please DAX1PDMB8E0 rev e
  • marcelofct
    • May 2019
    • 122
    • chile
    I have problems with this laptop hp 15-ak003la, it does not turn on the jackpower light, I have AC voltage 19v
    EC = 3.3
    charger BQ24780S
    vcc 19v
    acdet = 3v
    acin = 2.9v
    I press the power button and it does nothing
    please your help to fix it
    I attach a schematic
  • Sephir0th
    • Oct 2020
    • 1262
    Re: help me please DAX1PDMB8E0 rev e
    Voltages and Résistance to GND at PL29 and PL30?
    Also Check your Power switch: Does the 3.3V drop to Zero when you Press it?
    FairRepair on YouTube
    • marcelofct
      • May 2019
      • 122
      • chile
      yes the power button its ok
      i left the office , tomorrow i will edit the post with voltages and resistance :thank you
      • marcelofct
        • May 2019
        • 122
        • chile
        Edit :
        PL29 5v - resistance to GND 10k
        PL30 3.3v resistance to GND 4.4K
        • Sephir0th
          • Oct 2020
          • 1262
          That's Bad. I Had hoped that the issue is there...
          Now Check Voltage (Before and After) and Résistance to GND of each Coil and Share the values Here. Please add the Values of PL29 and PL30 Into the list.
          Check also whether a Voltage is Coming on at least for an blink of an eye after pressing the button.
          • marcelofct
            • May 2019
            • 122
            • chile
            what means bad... the board is shorted or its dead ?
            i wiil check the coils
            • Sephir0th
              • Oct 2020
              • 1262
              Check the coils Like suggested. When everything seems fine, we should try Flashing the BIOS First.
              • marcelofct
                • May 2019
                • 122
                • chile
                PL16 = 0.17 / resistance 720 ohm
                PL19 = 0v / Resistance 22 ohm
                PL20 = 0v / Resistance 16.2 ohm
                PL22 = 0v / Resistance 7.2 ohm
                PL26 = 0v / Resistance 7.2 ohm
                PL27 = 0v / Resistance 3.7 ohm
                PL28 = 0v / Resistance 3.7 ohm
                PL23 = 0v / Resistance 3.7 ohm
                PL29 = 5v / Resistance 10k ohm
                PL30 = 3.3v / Resistance 4.4k ohm
                PL24 = 0v / Resistance 21.5 ohm
                PL25 = 0.99v / Resistance 56 ohm
                when i press power button nothing happend no voltage
                • Sephir0th
                  • Oct 2020
                  • 1262
                  Besides PL19 and PL20 should be the Same Résistance, all the resistances seems fine. ALW voltages present, No obvious short.
                  Try Flashing known working BIOS First and pray. Otherwise it Would be a hard one.
                  I assume you're working With known working charger of correct wattage and known working RAM too, Otherwise make this Sure First.
                  • marcelofct
                    • May 2019
                    • 122
                    • chile
                    off corse : good ram an original charger working 100%
                    i will try a new bios
                    kbc is probramable, it will have to do with that ?
                    • marcelofct
                      • May 2019
                      • 122
                      • chile
                      I flash bios and nothing happend ,power button dOEs 3.3v when press the button drop to 0v maybe is a wrong dump i leave my dump if someone can check it out
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Do you have +3VPCU at pin5 of PU20?? What about AD_ID?? ACDRV Voltage on BQ24780??
                          • 20611
                          Bios moved to "Bios Requests ONLY!" section - https://www.badcaps.net/forum/showthread.php?p=1059029
                          • marcelofct
                            • May 2019
                            • 122
                            • chile
                            Now battery is charging :/ and. No power on when i press the power button next monday i'll check AD_ID and ACDRV is present i check again on monday
                            Thank you
                            • marcelofct
                              • May 2019
                              • 122
                              • chile
                              thanks for your help but i don't have the laptop anymore
