broke hp 840 g3 HDD slot motherboard
  • b310d
    • Jan 2020
    • Ethiopia
    I broke hp 840 g3 HDD slot motherboard. How can I fix it
  • Sephir0th
    • Oct 2020
    • 1289
    Re: broke hp 840 g3 HDD slot motherboard
    We need clear Picture(s) of the damaged area to Check what is necessary.
    FairRepair on YouTube
    • Byte_76
      Faulty memory slot on Tekram Slot 1 motherboard
      by Byte_76
      I have a Tekram P6PRO-A5 Rev. 1.01 which has an issue with one of the memory slots and with the floppy port.
      When a memory module is installed into the slot which is closest to the north bridge, the board will beep and won't post. The same memory module works in the two remaining slots.
      Also, the floppy drive does not work regardless of bios settings.
      Please help me to identify the possible cause of the faulty memory slot and the floppy drive port as well.
      I have examined the board under my digital microscope and did not find any broken traces....
      04-12-2025, 06:58 AM
    • Roli
      Lenovo C440 CIH61S1 motherboard , wont post with 1 slot of memory
      by Roli
      Hello , i got this lenovo C440 , with moderboard CIH61S1 , the problem is that when i put 1 memory in slot 1 the system wont post , ocasionaly it works but most of the time it doesnt and when it works , it gives BSOD-s and freezez a lot , if i put memory in 2nd slot , the system will work fine , if 2 put 2 memories again system will crash /freeze /bsod / or it wont post .
      I tried changinc CPU , other memory .
      05-01-2025, 08:48 AM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
    • glovecaps
      by glovecaps
      11-25-2024, 04:23 PM
    • totoagung2
      by totoagung2
      Totoagung2: Situs Slot Gacor Paling Gampang Jackpot di Indonesia 2024
      Hadirnya situs slot gacor gampang jackpot Totoagung2 yang menyediakan banyak sekali permainan slot terpopuler terkini yang hadir setiap tahun nya. Tentunya di Indonesia sendiri yang menjadi salah satu negara yang favorit bagi provider game slot. Banyak sekali pengembang permainan melihat negara tanah air Indonesia untuk menjadikan dan mencoba berbagai kesempatan bisnis judi online yakni games judi slot Totoagung2 terbaik dan terpercaya no 1. Hal itu juga dibuktikan dengan sangat banyaknya provider mesin slot...
      01-01-2024, 02:43 PM
