15V_ALW Issue on N4010
  • IamPritesh
    • Aug 2017
    • 354
    • India
    Hello friends, having difficulty finding the real culprit on 15V_ALW line. After pressing power switch I am only getting 8-9 Volt on the 15V_ALW
    SUS_ON has 3.3 V
    I have tried to isolate this by removing PR94, Pr69,PR80,PR67,PR312 still not able to figure out why 15V_ALW is 9V
    PQ19
    Pin 1- 15V
    PIN 2 - 5V
    PIN 3 - 9V
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • ugamazing
    by ugamazing
    12-17-2024, 07:05 PM
  • Simone Vergani
    Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
    by Simone Vergani
    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
    To assist with troubleshooting, I'm attaching two power circuit schematics:
    • Power
    03-05-2025, 02:25 PM
  • wizard13
    Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
    by wizard13
    I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
    I have checked the forum and the available documentation but could not find a solution specific to my issue.
    • Brand & Model: Dynabook Satellite Pro C50D-B-100
    • Part Number (P/N): PYU13E-00C00PFR
    • Serial Number (S/N): 22028896H
    • System Configuration (SC): A1PYU13E1127
    • Motherboard Model: IP3_ACN16_MB_V21_20211222A
    • Power Input: DC 19V –
    02-28-2025, 02:43 AM
  • Titus6
    LG OLE65C1 Stand-By issue
    by Titus6
    I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
    However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
    I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
    01-31-2025, 04:01 PM
