Lenovo G570 shorted vcore
  • String2016
    • Nov 2015
    • 2238
    • philippines
    I have here working with Lenovo g570 UMA version LA-675AP rev:1.0 , the problem is laptop turns on then a seconds it goes off, I already tried both flash main and ec bios but still same issue, I noticed the all tantalum 330uf and ceramic around cpu area are both shorted, tried replacing one of them PC711 still shorted, tried replace ISL 95831 PU601 still shorted, also tried removing each component and cpu but all caps are shorted, also PQ601 and PQ602 both drain connected to PC711 are all shorted, anyone can help on this please
  • mon2
    • Dec 2019
    • 14659
    Re: Lenovo G570 shorted vcore
    Vcore is often a low voltage power rail. Respectively, it is common to show low resistance on that rail. This does not imply a shorted component is on that rail.
    Post the resistance to ground on that rail.
    Post the schematic & boardview files for this logic board.
    • String2016
      • Nov 2015
      • 2238
      • philippines
      resistance on PC711 positive side 33.5ohms same with mosfet pq703 drain side
      • mon2
        • Dec 2019
        • 14659
        1) 33.5 ohms does not sound like a shorted part on this rail.
        2) Remove the battery & adapter. What is the resistance to ground on PL301, pin # 2 ? Checking for a low resistance on this rail due to a short.
        3) Do the same measurement for other coils on the logic board.
        • String2016
          • Nov 2015
          • 2238
          • philippines
          PL301 measures starts from 12mohms dropping 200k then rising up, Pr326 has 5.1ohms, the mosfet pq310 and pq313 resistance is fluctuating,
          • Spider1211
            • Oct 2019
            • 532
            • Mauritius
            Measure resistance on all coils and report back. Is the resistance fluctuating by a lot? Measure continuity in diode mode across PQ310 and PQ313.
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
            • coasterghost
              Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
              by coasterghost
              For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
              Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
              Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
              System Hardware:
              Processor: AMD Ryzen 7 PRO 5850U
              Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
              09-08-2025, 10:46 PM
            • mkdj
              Lenovo Thinkpad L480 : 3VALW rail shorted to ground, but I can't find the shorted component
              by mkdj
              Dear all,
              Laptop is Lenovo Thinkpad L480 (boardview can be found in this badcaps topic). When pressing the power button the LED power light turns on, but nothing else happens.
              I removed the motherboard, checked for shorts on the main inductors. I found that there is a short to ground on the +3VALW_P rail (@PL201). I soldered a wire on the PL201 inductor, and I injected up to 1.3V with my power supply. Current drawn is approximately 3.2A.
              I used a small thermal camera to locate the shorted component. But nothing on the board heats significantly, except the...
              08-11-2025, 04:55 AM
            • TevasLT
              Dell G3 3779 CPU and GPU vcore shorted
              by TevasLT
              I have water damaged Dell G3 3779.
              Things I did. During visual inspection i noticed PL911 filter was blown up and caps around it PC901, PC902 .. all up to PU901 shorted, found culprit shorted cap on top side of board PC905, removed cap and short up to PU901 is gone. Shorted PJP901 to bypass filter for the moment.
              problem is CPU and GPU vcore coils are all shorted aswell and I don't know where can I safely inject power to test which component or driver is bad.
              PLA01 20.8 Ohm PLI01 3.8 Ohm, PLI02 3.8 Ohm, PLI03 3.8 Ohm, PLI04 3.8 Ohm...
              11-10-2022, 06:55 AM
            • trepachka
              Lenovo Slim 7 14IAP7 NM-E412 shorted IC identification
              by trepachka
              Model: Lenovo Slim 7 14IAP7
              Motherboard: NM-E412
              Please, take a look at the enclosed photo and help me identify this IC. It is currently shorted, no boardview or schematics, I am unable to make out what this is.
              The chip has markings "Y182" on line 1 and "2898" on line 2.
              Thank you....
              02-26-2025, 11:15 PM
