Hp 15 laptop giving a blue screen
  • mnciks11
    • Aug 2019
    • 345
    • south Africa
    Hello guys I have an Hp 15
    EPW50 LA-G07FP
    REV : 1.0
    2018-08-21
    Facing a blue screen of death, when I searched the code online they said it got to do with ram, I changed the ram memory, I change the ram volts, seemed fine to me…
    I checked the cpu power supply mosfets , they seem fine to me…The bios was programmed by someone else, I don't suspect the bios anyway…
    Can someone clue me up please, i changed the rams, hdd, network cards , keyboard, everything but still
  • mon2
    • 14589
    Re: Hp 15 laptop giving a blue screen
    BSOD is often a Windows s/w related fault such as drivers, etc.
    Can you enter the BIOS configuration screen of this computer without the BSOD ?
    Remove the HDD and power up - does the machine power up and stay stable without the BSOD since there is no Windows to boot from ? If yes, attempt to boot from a live distribution of Linux using a USB media that you can download from the internet.
    Then use only this bootable USB thumb drive to load the Linux OS and check if it remains stable or not.
    Use the default BIOS configuration to load up safe mode defaults for the hardware parameters. Do check if there is a more current bios update from the HP website.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • slimmy182
      Need HELP troubleshooting solid Blue screen Nintendo Switch BSOD
      by slimmy182
      I recently got a switch which did not turn on (blu screen and could not do anything). It draws 15v so battery is charging as normal. I opened it, it's never been touched by anyone, rose old thermal paste still there and foam attached to the heat sync. On microscope I did not see any sign of corrosion or any particular damaged components, only dust. Completely cleaned the board with isopropyl alcohol and give a try with no luck. I cannot exclude that this consol had not being dropped to the ground since it has a sing on external enclosure. Anyway detaching the eMMC screen did not light up and enter...
      03-22-2022, 05:04 AM
    • gbbradshaw
      Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
      by gbbradshaw
      Hi.
      I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
      02-22-2023, 01:31 AM
    • siuras676
      Dell XPS Plus 9320 blue screen and rebooting
      by siuras676
      I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
      First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
      However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
      Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
      04-07-2025, 12:10 PM
