ASUS X441SC jumper for power?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi good day I want to jumper the unit with twizzer but I dont know where tojumper the pins
    in the boardview I cant see where the power
  • mon2
    • Dec 2019
    • 14616
    Re: ASUS X441SC jumper for power?
    See attached.
    Use tweezers to short pin # 2 (PWR_SW#) of resistor R3131 to GROUND.
    PS - found this through searching the NET NAMES till locating one that made sense and a bit of magic
    PS # 2 - Stay safe! Read about the recent storms
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Originally posted by mon2
      See attached.
      thanks sir it was working now
      • GLISIT
        by GLISIT
        01-16-2025, 02:29 PM
      • PantherDave
        by PantherDave
        Hi all!
        05-29-2024, 02:01 PM
      • ShadowAi
        ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
        by ShadowAi
        Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
        Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
        After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
        03-15-2024, 10:46 AM
      • meraklinetx
        Asus Z97-a power cycle, no boot no cpu voltage
        by meraklinetx
        Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
        05-10-2023, 06:08 AM
