DAG7BJMB8C0 5V regulator chip
  • Dinneke
    • Apr 2014
    • 154
    • Netherlands
    Liquid damage, 5V rail shorted, RT3662AC removed and short is gone.
    5V regulator not working, also short at output, regulator is marked BACCDK its's a QFN20 package.
    Does anyone knows wich regulator it is?
    No schematic.....
    • 21889
    Re: DAG7BJMB8C0 5V regulator chip
    It could be a silergy SY8288CRAC - https://www.badcaps.net/forum/showpo...1&postcount=12
    See page 26 in the Quanta ZHP schematic - https://www.badcaps.net/forum/showthread.php?t=77302
    • Dinneke
      • Apr 2014
      • 154
      • Netherlands
      Thanks!
      • acedogblast
        by acedogblast
        11-02-2024, 05:13 PM
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • mferna14
        ASUS TP412F 3.3V Regulator chip gets very hot
        by mferna14
        Hi all., I am working an ASUS TP412F​., motherboard Model TP412FAC R: 2.0. The problem I am facing is the 3.3 buck converter (L8=7J RT6256BGQUF) gets very hot when 19v is applied through DC-in jack. I don't think Schematics or Boardview is availble for this model. The chip get so hot that I can't even take the voltages of the pins. I replaced the chip but the problem is still there, new chip even gets very hot. The input on pin 5, 19v is present. So I removed the Output coil & the chip & checked the voltages on the chip pads which are as below: Please view if any volts seem to be abnormal....
        07-09-2024, 11:57 AM
      • Troystain
        Help EZP2023+ updated chip database for w25q256jveq?
        by Troystain
        Hello, anyone here have updated ezp2023+ chip database in .dat file format.
        I need to add w25q256jveq chip but I do not know what data should I type.
        I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
        The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....
        11-25-2024, 12:53 AM
