MacBook pro 13" mid 2017 A1708 dead cpu?!
  • sebulica
    Beginner
    • Mar 2014
    • 50
    I have a strange issue with a macbook pro.It works fine for 1-2h and after that is dead unles i leave it to rest for a long period of time.This could be concludent with a heat related issue...but the only thing heating up is the CPU.I use "hwsensors" for temperatures display and "macs fan control" for turning the fan up to keep the device cooler.I have tried to turn the fan all the way up but to no avail,as the issue persists.
    So,when the strange occurs,the screen goes blank and stops responding to any command.I can still see the backlight but no picture on sight.If i keep the power button pressed the backlight dissapears and the fans go silent,but the CPU remains hot unless i disconnect the battery.I doesn't matter the key combination or if i perform pram reset,smc reset or anything,the sistem does not start unless i leave it to rest for at least 5-6 h.
    When i start the macbook again after a long period of patience,i get a message that informs me about the OS crash and the issue points panic(cpu 0 caller).
    I have measured the voltage to cpu,ram,ssd and is fine,I tried another ssd,battery and display,fresh os install but still the same.
    Is there any possibility that the cpu is not dead and there might be another reason for this issue?
    There is no water damage,mechanical shock or anything.The laptop was used in an office for daily common tasks and the issues started suddenly after about 2 years of usage.
    Thanks!
  • mon2
    • 14659
    Re: MacBook pro 13" mid 2017 A1708 dead cpu?!
    Have you attempted to apply fresh heatsink compound on the CPU?
    • sebulica
      Beginner
      • Mar 2014
      • 50
      That was my first thing to do,and the thermal compound was good enough...i've seen worse.
      I will check the temperature with an arduino tomorrow to see if the reported temperature matches the one checked externally.
      • sebulica
        Beginner
        • Mar 2014
        • 50
        The temperatures are somewhat close but a little higher than reported,but i have found another interesting thing...if i remove the battery,no more heathing up and no more errors.
        I will see if i can get another battery to test...but in the meantime it works just fine with the power adapter connected.
        Has anyone seen something similar?
        • sofles
          Macbook a1707 2017 model 820-00928 GPU issue
          by sofles
          Hello there
          I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
          I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
          11-21-2024, 05:25 AM
        • CG_Dionysos
          MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
          by CG_Dionysos
          I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
          • Model: A1707
          • 15-inch, Mid 2017
          • 3.1 GHz Core i7
          • 16 GB RAM
          • Radeon Pro 560
          • 1 TB SSD
          • Board number: 820-00928-A
          I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
          Thanks in advance!
          Greetings from Germany...
          09-16-2025, 06:43 AM
        • jesi
          macbook pro a1707 dead
          by jesi
          hi all techs
          require some help on this 820-00281-A macbook motherboard came in dead and the pch bga U1100 (SR2NH), u5000 , Q7056 , U7000 and bios U6100 ,looks like these have been tampered with ..also the battery is swollen..
          adapter usb c 20.5v 4.7a 96w , i persume it should power on mb without battery..
          update:
          when adapter plugged in , power switch which 3.3v on it , when power button pressed both fans come on after 6 secs for about 20secs approx then goes off , nothing on the display stays as blank.. the voltage at the usbc out start from...
          08-24-2025, 04:34 AM
        • robka
          MacBook Pro 2018 - A1990 Dead - not charging - only 5V
          by robka
          my MacBook Pro 15" 2018 Touch Bar (A1990) doesn't charge anymore. Board# 820-01041-A
          I'm not experienced in diagnostics, but I want to try to solve the problem with your help, because every local shop charges around 600€ (650 usd). Which is the value of the whole Macbook.
          The Macbook was charging when suddenly the "charging sound" appeared every other second for around 4-5 times.
          After that the Macbook was dead. It isn't charging anymore.
          The USB-C Port where the charger was plugged is burned. Also The Cable and the...
          03-02-2024, 02:58 PM
        • stefanbs
          Fit 820-00244-А board in Apple Macbook A1534 2017 820-00687-А
          by stefanbs
          The laptop is Apple Macbook A1534 2017 with board 820-00687-А. The USB-C tester shows no voltage, there is 820-00244-А board available. I looked at both schematics, all connector signals seem to be the same. Did someone try to fit 820-00244-А board in A1534 2017?
          05-11-2025, 01:08 AM
