Panasonic CF-54 lan faulty
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hi, for this laptop a lan not working !
    what to do, advice please.
  • mon2
    • Dec 2019
    • 14022
    Re: Panasonic CF-54 lan faulty
    Can you see the LAN controller in your Device Manager of Windows ? If yes, then the LAN chip is being seen by the motherboard. That is a good start.
    Check the RJ45 connector pins that you use for mating the Ethernet cabling. Do any of the pins look bent to you? The connector may need to be replaced.
    Otherwise, you will have to open up the laptop to inspect near the LAN connector to check for possible high transient damage that is possible for this port.
    A quick fix is to just source a low cost USB Ethernet dongle. If you do this, source a USB 3.0 to Gigabit dongle (Asix or Cypress are good chipsets).
    • Fabbrone
      • Jun 2015
      • 158
      • italy
      Windows sees it in the peripheral list and visually disassembling it, everything looks ok even the connector pins. I'd rather fix it
        • 20695
        Do you know the history of the laptop , was the bios flashed recently.Is the LAN disabled in bios settings. Can you boot from linux and get a MAC address
        • vinceroger69
          • Mar 2012
          • 6714
          Are you getting the network cable unplugged error i had this issue the other day on a laptop this guide helped
          https://thegeekpage.com/fix-windows-...plugged-error/
          • Fabbrone
            • Jun 2015
            • 158
            • italy
            Thanks to all, I still solved it by following the attached link
            • vinceroger69
              • Mar 2012
              • 6714
              Glad you managed too fix the issue it took me a few hours too figure it out myself, this happened when updating a pc to windows 10 it was working fine on wireless but i like too make sure all ports etc work before i pass a pc on.
              • dgnisbet
                Panasonic Tx-P50G20B faulty main board
                by dgnisbet
                I have a Panasonic viera plasma Tx-P50G20B which has a faulty main board. The picture freezes after about 30s and appears to lose vertical hold before finally going black. The main board part number - TNPH0838 (1) A - is common to several Panasonic tvs across a number of ranges however there is a second part number (TXN/A1LTUB for the 50") which is unique to each model.
                My question is, given that the TX-P50G20B 50" differs from the TX-P46G20B 46" only in the physical size of the screen, is it possible to use the main board from the TX-P46G20B in a 50"? The secondary...
                02-03-2022, 02:01 PM
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • corrize
                Where to find a very small fpc connector 0.3mm between 2 pins ?
                by corrize
                Hello, I search this connector (oxydated).
                It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                Do you know how to find this connector please ? What is the exact name for find it ?
                08-06-2024, 05:25 PM
              • AquaMan Ua
                by AquaMan Ua
                05-17-2025, 09:40 AM
              • SFETech
                Panasonic P50S30 SC board pins 1-3 Short
                by SFETech
                I'm aware pin 3 is ground, but pin 1 is shorted to pin 3 even when not mounted to the machine. It's happening on the original board as well as the ordered replacement board. TV is giving 14 blinks. I'm trying to troubleshoot the machine and thought I'd figured it out when I found a pin that wasn't labeled as ground (Pin 1) shorted to ground, but now I'm just trying to verify if I have two boards with the same fault or if that's how the board is designed and I'm looking in the wrong area.
                04-14-2022, 08:11 AM
