Asus n550jv rev 2.1 no power
  • Zilicon
    • Nov 2020
    • 142
    • Nigeria
    Greetings...
    please I need your help in troubleshooting the above PCB, voltage gets to PQ8801 mosfet but the mosfet doesn't open as there was no voltage at the gate. i traced the gate to the IC (PU8801) that was meant to generate the voltage, but 0V at pin 4, I.ve changed the IC but still the same result.
    please help, i'm out ideas and i could not lay my hands on the schematics only the boardview is available. suggestions would highly be appreciated.
  • mon2
    • 14191
    Re: Asus n550jv rev 2.1 no power
    hi. place your meter in resistance mode, turn off / remove all power. Check the resistance to ground on each and every coil. If you see a very low resistance value, then that rail may be a low voltage rail (ie. CPU core voltage of 1v0 or 1v05, etc.) OR could be a rail with a shorted cap. Bad caps are usually the polarized tantalum style that over time, just die and try to take down the owner with them.
    Have repaired a number of logic boards with this process.
    You can also check for dry solder joints on the COIL(s) and nearby mosfets. Over time, the ROHS solder can become brittle / crusty and causes hairline cracks that fail eventually.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      DC-in mosfets are not shorted?? Most common problem in asus is one of the two dc-in mosfet gets shorted. So do check that first.
      • Zilicon
        • Nov 2020
        • 142
        • Nigeria
        not shorted at all, I even changed both N-channel FETs but still the same
        • Zilicon
          • Nov 2020
          • 142
          • Nigeria
          these are the readings at the coils:
          PL8801 90k
          PL8701 0k
          PL8003 0k
          PL8002 0k
          PL8502 0k
          PL8501 0k
          PL8200 0k
          PL8301 0.6k
          PL8100 14.4k
          PL8101 14.4k
          L3901 29k
          L3901 29k
          please what do you think?
          plus i see no sign of short on the board
          • myth77
            • Feb 2017
            • 380
            • Croatia
            Are those readings ih Kohm for all coils? You can not read in Kohm many of these Coils because they have much lower resistence to the ground...some even few ohms.
            Use your multimeter in ohms for that that you measure 0k and post back results.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              post PU8801 pin voltages here.
              • Zilicon
                • Nov 2020
                • 142
                • Nigeria
                yes there were taken in Kohms.
                ok i will update you ASAP
                • Zilicon
                  • Nov 2020
                  • 142
                  • Nigeria
                  ok thanks.
                  i will do that ASAP
                  • Zilicon
                    • Nov 2020
                    • 142
                    • Nigeria
                    Originally posted by Zilicon
                    ok thanks.
                    i will do that ASAP
                    the PU8801 voltage pin
                    1 0.7v
                    2 0.7v
                    3 0v
                    4 0v
                    5 0v
                    6 2.5v
                    7 0v
                    8 0v
                    9 0v
                    10 0.1v
                    11 0v
                    12 1.1v
                    13 1.1v
                    14 GND
                    15 0v
                    16 6v
                    17 5.8v
                    18 1.1v
                    19 1.1v
                    20 18.8v
                    • Zilicon
                      • Nov 2020
                      • 142
                      • Nigeria
                      PL8801 327k (it appears i made mistake in the previous reading)
                      for the low resistance reading:
                      PL8701 77.6ohms
                      PL8003 19.8ohms
                      PL8002 19.8ohms
                      PL8001 19.8ohms
                      PL8501 8ohms
                      PL8502 80hms
                      PL8200 76.6ohms
                      every other coils remain the same, they read in Kilo ohms
                      • Zilicon
                        • Nov 2020
                        • 142
                        • Nigeria
                        Asus n550jv rev 2.1 not turning on
                        Hello Friends,
                        PU8801 pin voltage
                        1 0.7v
                        2 0.7v
                        3 0v
                        4 0v
                        5 0v
                        6 2.5v
                        7 0v
                        8 0v
                        9 0v
                        10 0.1v
                        11 0v
                        12 1.1v
                        13 1.1v
                        14 GND
                        15 0v
                        16 6v
                        17 5.8v
                        18 1.1v
                        19 1.1v
                        20 18.8v
                        • questore
                          • Dec 2015
                          • 500
                          • csongrád
                          Re: Asus n550jv rev 2.1 not turning on
                          Test the following points of sequence and write down voltages:
                          (your pin nr 5 is 0v means some default voltage rails is probably missing (one of 3v 5v etc))
                          1A +3VA -
                          1B +5VA -
                          2 PS_ON -
                          3 +3VA_EC -
                          4 EC_RST -
                          5 3VA_DSW_ON -
                          6 3VA_DSW_PWGD -
                          7 DPWROK_EC -
                          8 ME_AC_PRESENT -
                          9 PCH_SLPSUS# -
                          10 5VSUS_ON -
                          11 3VSUS_ON -
                          12 5VSUS_PWRGD -
                          13 +3VSUS_PWRGD -
                          14 PM_RSMRST# -
                          15 PCH_SUSACK# -
                          16 ME_SuspwrDnAck -
                          17 PWR_SW# -
                          18 PM_PWRBTN# -
                          19 PM_SUSC# -
                          20 PM_SUSB# -
                          21 SLP_A# -
                          22 SUSC_EC# -
                          23 SUSB_EC# -
                          24 1.35V_PWRGD -
                          25 +1.05VS_PWRGD -
                          26 P_1.5VS_PWRGD -
                          27 ALL_SYSTEM_PWRGD -
                          28 VRM_PWRGD -
                          29 PM_PWROK -
                          30 H_DRAM_PWRGD -
                          31 DRAMPWROK -
                          32 H_CPUPWRGD -
                          33 PM_SYSPWROK -
                          34 BUF_PLT_RST# -
                          35 NVDD -
                          • questore
                            • Dec 2015
                            • 500
                            • csongrád
                            1A +3VA -
                            1B +5VA -
                            2 PS_ON -
                            3 +3VA_EC -
                            Forget about all that.
                            Pin #5 is "ACOK" signal:
                            AC adapter detection open drain output. It is pulled HIGH to external pull-up supply rail by external pull-up resistor when
                            voltage on ACDET pin is between 2.4V and 3.15V, and voltage on VCC is above UVLO and voltage on VCC pin is
                            275mV above voltage on SRN pin, indicating a valid adapter is present to start charge. If any one of the above
                            conditions can not meet, it is pulled LOW to GND by internal MOSFET. Connect a 10kΩ pull up resistor from ACOK to
                            the pull-up supply rail
                            I think since your ACDET és 2.4< 2.5v <3,15 and VCC is close enough to 19V
                            you should replace the charger chip.
                            Question: Are you sure pin #11 BATDRV is 0v? Resistance on that pin? Is your battery disconnected?
                            • Zilicon
                              • Nov 2020
                              • 142
                              • Nigeria
                              THANK you so very much, I changed the chip again and it worked. thank you!
                              the previous chips must have been bad because, i got them from donor boards.
                              Last edited by piernov; 05-21-2021, 12:59 PM. Reason: remove full quote of previous post
                              • Zilicon
                                • Nov 2020
                                • 142
                                • Nigeria
                                thank you guys for your help, the board is working now. I changed the chip again, the previous chips must have been bad because i got them from donor boards.
                                Thanks again and again and again
                                • questore
                                  • Dec 2015
                                  • 500
                                  • csongrád
                                  Glad that it worked!
                                  • Scotchmist
                                    Asus GA502D keeps blowing mosfet
                                    by Scotchmist
                                    I have an Asus GA502D, it had a blown mosfet which I replaced and the laptop booted into windows, a few mins later it shut off, the same mosfet was blown. I thought maybe just a bad mosfet but same thing happened again, a few mins in windows and shuts off.
                                    I have removed the mosfet and can run the laptop no problem
                                    The MOSFET is FDPC5018SG
                                    Can anyone point me in the direction of what could be the cause of this, could it be the controller rt3663bc?
                                    08-24-2024, 02:23 PM
                                  • MicroSMD Lab
                                    by MicroSMD Lab
                                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                                    01-10-2024, 06:36 AM
                                  • Chewy6288
                                    Asus FA506QE missing MOSFET
                                    by Chewy6288
                                    I recently bought this laptop to try to fix up because it was so cheap. It has no power so I figured it was a MOSFET or cap issue so I started with taking it apart, but when I had it apart I noticed one of the MOSFETs was missing. I'm new to this so I don't know where or how to look up what to replace it with. I do have the boardview for it so I somewhat know what was there which I attached ,and the missing piece is PQ303....
                                    07-30-2025, 07:24 AM
                                    ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
                                    This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                    09-07-2024, 02:50 AM
                                    ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                    This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
