Hello, this time i am fighting with a laptop motherboard that initially didn't turn on at all, completely dead.
After inspecting it, I found a shorted capacitor, for those who have the boardview, the code is C5564.
After removing that and powering the board, the red charging led turns on and there seem to be life around the board. I poked with the multimeter some inductors but there are few of them that doesn't have any voltage.
The voltages that are presents are 3.3V on inductor PL80701 and 5VSus on inductor PL8702. Also 1.0Vsus is present
The current that the board draw in this state is 20mA
When i try to press the power button, the power led lights up but after a second both leds turn off and then only the red led stays on. The board goes to protection i think, something is still not good.
During this stage the amperage peak is roughly 220mA until the board shuts down.
I have the boardview but I don't know where to continue searching.
So far I've tried to sense the voltages on the Charger manager IC PU8901 and all the voltages are present (P_CHG_ACOK, etc)
The part of the board that doesn't have any voltage is the double phase cpu power supply, the one with the mosfets PQH9103, PQH9101 etc. The 19 volt arrives but there is no voltage at the gates.
Also there is no voltage on the inductors PL9301, PL8600, PL8101 8102
On the battery charger connector I sensed 12V and when the battery is connected the voltage drop and it doesn't seem that the battery is being charged. On the mosfet PQH8901 I sense 19 coming in and 12V coming out and on the next one (PQL8901) 12 Volts coming in but 0 coming out with zero voltage at its gate.
Could be that power charger IC that I already checked to be faulty?
What or where should I check?
Any hints are very appreciated.
