Toshiba Satellite - Locks up when plugged in
  • trebo
    • 514
    • Wales, UK
    #841
    Re: Toshiba Satellite - Locks up when plugged in
    Originally posted by fabiog
    To continue, the problem is software related the latest antivirus program update was causing the freezing, I feel so silly now lol.
    I didn't have to open the laptop and resolder new caps but since the symptom made me think it was related to the caps I only reinstalled the VGA driver and then went straight for the board ,the key thing to remember with this motherboard and NEC problem is that it hangs + shutsdown.
    I'm glad it's working now and I wont be replacing the new caps I added it will have to stay like this .
    would be interested to know whose antivirus update it was?
    • fabiog
      • Jul 2011
      • 102
      #842
      It was Avast latest program update ,I installed an older program version and seems to be behaving ,something conflicting it seems with latest release.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        #843
        Here is another job from yours truly. This time i used some different capacitors that had an extra negative terminal in the middle, protruding from the sides. This allowed me to place them back to back and not have to scrape the solder mask any. Looks clean and works perfectly.
        A working TV? How boring!
        • JackD
          • Sep 2015
          To ALL the posters on this forum, but especially Notsosure and rievax 60, thank you so much for all your info, my Toshiba A300 started to misbehave late last year and I stuck it in a cupboard thinking that it was probably the power supply, and one day I would buy a new one, anyhow, fortunately prior to spending money I did the research and found this forum, great resource, I have replaced my OE 907 with 4 of the Tantalum caps that Notsosure recommended from RS, cost $17AU....the thing now rocks! THANK YU ALL.
          • horol001
            • Oct 2015
            • 6
            • UA
            #845
            This question has a Toshiba L300 laptop is a known problem in our country are sold only tantalum capacitors 330 microfarads 6,3v or 10 volts suit if they return 2.5V.
            Такой вопрос: имеется ноутбук Toshiba L300 с известной проблемой у нас в стране продаются только танталовые конденсаторы на 330 мкф 6,3в или на 10 вольт подойдут ли они взамен 2,5в.
            • horol001
              • Oct 2015
              • 6
              • UA
              #846
              whether you can put 4 x 330 uF 6,3v?
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                #847
                Yes you can use 330uF 6.3v.
                • horol001
                  • Oct 2015
                  • 6
                  • UA
                  #848
                  I hope this information is checked) as the laptop colleagues
                  • horol001
                    • Oct 2015
                    • 6
                    • UA
                    #849
                    293D337X96R3D2TE3 such an approach?
                    • horol001
                      • Oct 2015
                      • 6
                      • UA
                      #850
                      VISHAY 293D337X96R3D2TE3 SMD D (7343-31)
                      Размер корпуса, LWH (мм) 7,30x4,30x2,90
                      Емкость 330uF
                      Допуск (±%) 10
                      Рабочее напряжение (В) 6,3
                      Рабочая температура (°С) -55…125°C
                      • mockingbird
                        • Dec 2008
                        • 5488
                        #851
                        Емкость 330uF
                        Допуск (±%) 10
                        No!
                        Only 0.60 ESR and 500mA ripple rating. Not good enough.
                        • horol001
                          • Oct 2015
                          • 6
                          • UA
                          #852
                          found on a Chinese website see if they fit spetsialistі
                          http://ru.aliexpress.com/item/Free-S...rchweb201560_9
                          • mockingbird
                            • Dec 2008
                            • 5488
                            #853
                            Part number is OK, but Aliexpress will send you fake parts.
                            I have Kemet A700:
                            Part number: A700X477M2R5ATE010
                            2V 470uF ESR 10mOhm Ripple 4700mA (Dimensions: 7.3mm 4.3mm 4.0mm)
                            Part number: A700X277M004ATE015
                            4V 270uF ESR 15mOhm Ripple 3900mA (Dimensions: 7.3mm 4.3mm 4.0mm)
                            Please note that these are "X" size case, and they are taller than "V" size (2.0mm) and "D" size (2.8). So I don't know if they will fit.
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #854
                              Some parts from Aliexpress sellers are bad in some way.
                              I have found these to be ok.
                              http://www.aliexpress.com/item/Free-...699744043.html
                              • mockingbird
                                • Dec 2008
                                • 5488
                                #855
                                That seller's ICs are almost certainly fake. I have bought MOSFETs from AliExpress before and they were obvious fakes...
                                It's not necessarily impossible that he would sell a quantity of 50 tantalum caps with a value of $3+ each for $10 total, just make sure they really test 9mOhm and 330uF before you use them.
                                • eniac22
                                  • Jun 2012
                                  • 125
                                  • Greece
                                  #856
                                  Hi i have replace the nec tokin with 4 330uf 2.5v tantalium capacitor on my toshiba a300-20w but the laptop is working ok only without the battery, when i have connect the battery and the charger the laptop shutdown unexpected. Any advice?
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #857
                                    They seem to be ok. I am now half way through my 2nd order of 50. I have used most of them in my own collection of A200 laptops. The ESR must be ok because the laptop will work after fitting the first 2 capacitors.
                                    The seller has 29 orders with good feedback.
                                    I have been bitten by fake parts through Ali-express. It can take a lot of time and effort to prove that the parts are at fault and not another cause.
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #858
                                      Are you saying that the laptop works normally when powered from the charger only?
                                      • eniac22
                                        • Jun 2012
                                        • 125
                                        • Greece
                                        #859
                                        Yes, i use this capacitor from ebay maybe is crap but i remember that i have use it again without problem
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #860
                                          Im still trying to make sense of this. While the laptop is being powered from the charger only, what happens when you insert the battery?
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
