Toshiba Satellite - Locks up when plugged in
  • inflex
    • Aug 2012
    • 544
    Re: Toshiba Satellite - Locks up when plugged in
    Hi folks, just thought I'd double-check / cross-check here on a fault.
    Received an A300 the other week from client, usual symptoms, machine won't stay on, thought it was the typical TOKIN problem, replaced it with a 10x 100uF 1206 ceramic array, but the symptoms are still there. Looking closer I noticed that the power icon light flashes from white -> orange -> white a couple of times before it shuts down just prior to getting underway with booting after the POST.
    Still a cap fault / TOKIN issue... or does this sound like something else completely?
    YouTube Repair Videos - https://www.youtube.com/user/19PLD73
    FlexBV BoardView software - Linux/OSX/Windows - http://pldaniels.com/flexbv
    • mockingbird
      • Dec 2008
      • 5484
      #782
      Does it have a Radeon GPU or IGP?
      • mcrap
        AdvancedBF
        • Nov 2014
        • 5
        • Portugal
        #783
        People I need you´re help, I Got a toshiba satellite L40-18L from portugal where it has the symptoms of the other toshiba´s here (Doesn´t start, when he does sometimes he shutdown at any time) but this doesn´t have the Nec chip...
        Only 5 smd black components that I didn´t even know if they are capacitors or diodes...
        Some say 330 7NMq and the others 100 821BE...
        what is this and how can I measure them?
        • Marbc
          • Jan 2015
          • 8
          • Philippines
          #784
          Hi everyone! I have a question regarding the four foil strips where the TOKIN is mounted. Are the two inner negative foil strips connected together? Or can the two negative foils be soldered together?
          • rievax_60
            • May 2012
            • 897
            • australia
            #785
            If it's a Toshiba Satellite A200 or A300 or similar, then yes, the two inner tinned copper areas that look like strips are part of the one continuous piece of PCB copper print. The space in between is just covered with green Solder Resist.
            There is no need to connect them. There may be a need to connect them on other brand mainboards.
            DO NOT scratch the PCB as others have done, if you don't want to ruin your mainboard.
            • inflex
              • Aug 2012
              • 544
              No. Just a standard Intel Centrino model, no nVidia GPU.
              • mockingbird
                • Dec 2008
                • 5484
                #787
                What's the full model?
                • mcrap
                  AdvancedBF
                  • Nov 2014
                  • 5
                  • Portugal
                  #788
                  Anyone can help me?
                  • Marbc
                    • Jan 2015
                    • 8
                    • Philippines
                    #789
                    Thank you so much for the info rievax_60. The reason I asked the question was because I planned to solder a thin copper foil over the two inner negative terminals; but now with you info, I would just scrape off the solder resist to expose the copper print so as to make it easier to solder four tantalum capacitors on it. Thanks for the help.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      #790
                      Just to make this clear. It's ok to scrape Resist from copper areas. You must not scrape or scratch any exposed fibreglass areas.
                      • Marbc
                        • Jan 2015
                        • 8
                        • Philippines
                        #791
                        OK I got it. Thanks
                        • inflex
                          • Aug 2012
                          • 544
                          what's the full model?
                          a300 ; psag4a-02m00m
                          • mockingbird
                            • Dec 2008
                            • 5484
                            #793
                            As I suspected. Your model has an "ATI Mobility Radeon HD 3650" GPU. What you need is to do is to reball the chip to get it working again.
                            If you don't want to invest that kind of money, I suggest you sell the CPU. T9300 should go for $50+ alone.
                            • mcrap
                              AdvancedBF
                              • Nov 2014
                              • 5
                              • Portugal
                              #794
                              No solution for the Problem of the Toshiba Satellite L40-18L?
                              It doesn´t turn on and when he does he just take a few seconds or minutes to shutdown for himself...
                              • zinksoft.net
                                • Nov 2013
                                • 17
                                • malaysia
                                #795
                                when have a ATI and nvidia GPU onboard. really nothing can be done already. try so many time remain failed. feel like manufacturing design the board this way, 2-4 yrs new notebook, wow.
                                • mockingbird
                                  • Dec 2008
                                  • 5484
                                  #796
                                  That's PSL48E.
                                  I'm pretty sure this motherboard doesn't have the Nec/Tokin capacitor. You're problem is most probably something else.
                                  I'm pretty sure you can get re-balling done inexpensively in Malaysia, no?
                                  • inflex
                                    • Aug 2012
                                    • 544
                                    Right, well that caught me off guard then. Not really going to bother with the reballing, don't have the equipment on hand to do the job right ( while I do reflows in the oven, and hot air, I really don't like doing BGAs without an infrared workstation )
                                    Many thanks for your time in assisting me.
                                    • bonniedoon
                                      • Jan 2015
                                      • 22
                                      Please please help me with this problem fix
                                      I recently fixed my Toshiba A300 using 4x SMD Tantalum Capacitors 330uf 2.5v
                                      and its still going great.
                                      So I got out my other A300 and decided to do the same fix, WITH BIG PROBLEMS.
                                      When I turn the Laptop on it fires up initially with only a black screen then about 20 seconds later it turns off. HELP
                                      So I've taken the caps off, on the mother borad I tested the + & - with a meter and the ohms reading is 0.00, IS THIS NORMAL
                                      What should I do now, I tested the caps the meter reading starts out with a low reading then rises to about 19.8 the decreases, IS THIS A GOOD SIGN?
                                      PLEASE WHAT SHOULD I DO NOW?????
                                      • rievax_60
                                        • May 2012
                                        • 897
                                        • australia
                                        #799
                                        Re: Please please help me with this problem fix
                                        I didn't follow all of that. The +&- on the PCB where the NEC/TOKIN capacitor was should be about 5 ohms with the CPU in its socket and in the K ohm range with the CPU out.
                                        Best to show us a photo of what you have done. Others have ruined their mainboards by too much scratching trying to clear shorts.
                                        • bonniedoon
                                          • Jan 2015
                                          • 22
                                          Thanks for your help rievax. here is a photo of the caps on the board. Today I took the 4 caps off then replaced with 5 of the same.
                                          Now when you turn the laptop on, it immediately turns off. Sometimes when you turn it on, the hard drive light flashed then turns off, then it switches on for a 1/2 a second then turns off.
                                          The caps I used on the previous A300 success shows ( 330 e67 ) on the front. However the ones I used on this A300 shows ( 330 e12 ).
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
