Toshiba Satellite - Locks up when plugged in
+ More Options
Posts
  • eniac22
    • Jun 2012
    • 124
    • Greece
    #861
    Re: Toshiba Satellite - Locks up when plugged in
    Originally posted by rievax_60
    Im still trying to make sense of this. While the laptop is being powered from the charger only, what happens when you insert the battery?
    Only with the charger work ok, when i but the battery while i have the charger and the system runing after a few sec will shutdown.
    The battery is not charging and also i get a message that say i must replace it.
    I will try with a new battery
    • predator0357
      • Jul 2014
      • 159
      • Israel
      #862
      i have the same prob A300. but my Q is if i can remove the tokin cap with heat gun and thermo laser gun???
      • rievax_60
        • May 2012
        • 897
        • australia
        #863
        yes, you are likely to be able to and make a mess as well. It is difficult to apply heat to where it is needed without the part melting an falling to pieces. It is much safer to gouge it off the PCB. It is not necessary to scratch the crap out of the PCB in the process.
        https://www.badcaps.net/forum/showthread.php?t=46821. Look at my photos in post #6.
        • predator0357
          • Jul 2014
          • 159
          • Israel
          #864
          Hi tnx 4 the help.
          but i dont care if the tokin will melt of fall in to pieces cuz its dead already ;-)
          P.S
          I forgot to ask if i can do it without removing things from the MB???
          • rievax_60
            • May 2012
            • 897
            • australia
            #865
            Originally posted by predator0357
            Hi tnx 4 the help.
            P.S
            I normally don't. You will risk melting the solder under the CPU socket. Also, leaving the CPU and heatsink attached might draw away a lot of heat.
            Causing extra damage to the mainboard is the main thing to worry about.
            • predator0357
              • Jul 2014
              • 159
              • Israel
              #866
              So i havve to remove the CPU even if i dont use heat gun? But after i remove the tokin i will need to apply heat anyway to solder the new caps and the CPU will drew heat also so whats the different?
              • rievax_60
                • May 2012
                • 897
                • australia
                #867
                No need to remove the CPU if you are going to gouge the capacitor off. A good soldering iron with a large tip is all that is needed to fit the replacements. I use a Hakko 936A clone with a K tip. A soldering iron heats a small area.
                There is lots more detail in this thread. Did you see the other post that I mentioned earlier?
                • predator0357
                  • Jul 2014
                  • 159
                  • Israel
                  #868
                  Why did u add solder between the caps?
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    #869
                    To connect their (-) ends to the ground print. The green coating is called Solder Mask which needs to be scraped away to expose the underlying copper print so that is can be soldered to. Excessive scraping will ruin the mainboard.
                    You need to read more of this thread. You forgot to answer my previous question. It is sometimes difficult to know what is being ignored.
                    • predator0357
                      • Jul 2014
                      • 159
                      • Israel
                      #870
                      But the outer line are + and the inner lines are - so why we need to add (-)?
                      I did saw ur post it was helpful 4 me tnx.
                      • rievax_60
                        • May 2012
                        • 897
                        • australia
                        #871
                        The (-) tabs under the capacitors do not overlap the original (-) solder pads/stripes. Other members solder their replacement capacitors at an angle so that the capacitor tabs can be soldered directly to the original pads.
                        • predator0357
                          • Jul 2014
                          • 159
                          • Israel
                          #872
                          So if my caps (-) touchs the (-) terminal i dont need to do what u did,right?
                          • rievax_60
                            • May 2012
                            • 897
                            • australia
                            #873
                            That's right, if you can solder it properly. You have no electronics experience?
                            What equipment do you have?
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #874
                              Mainly what soldering iron do you have?
                              • predator0357
                                • Jul 2014
                                • 159
                                • Israel
                                #875
                                I have exp n i have soldering gun hakko 30->130w
                                • predator0357
                                  • Jul 2014
                                  • 159
                                  • Israel
                                  #876
                                  hi
                                  what about this vid https://www.youtube.com/watch?v=cgH7RYiSkkY
                                  what do u think?
                                  • rievax_60
                                    • May 2012
                                    • 897
                                    • australia
                                    #877
                                    hi
                                    what do u think?
                                    Dont do that if you want your laptop to work again. I have explained a safe method. Read more of this thread to see other members' experiences, good and bad, and avoid the unnecessary scratching.
                                    Send us a photo of your iron clearly showing the tip.
                                    • predator0357
                                      • Jul 2014
                                      • 159
                                      • Israel
                                      #878
                                      Ok tnx 4 the helpπŸ˜ƒ
                                      I ordered hakko tips, all of themπŸ˜ƒ.
                                      • predator0357
                                        • Jul 2014
                                        • 159
                                        • Israel
                                        #879
                                        Heres my soldering iron HAKKO PRESTO 981
                                        • rievax_60
                                          • May 2012
                                          • 897
                                          • australia
                                          #880
                                          I didnt even know that iron existed. It would take some practice to get the heat right. I use a K tip or large chisel tip. The rest depends on your soldering skill.
                                          Check the resistance of the CPU between the (+) and (-) pads before you start. Then check it after you have fitted the new capacitors to be certain there is no short circuit caused by the soldering.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
