Toshiba Satellite - Locks up when plugged in
  • spleenharvester
    • Mar 2010
    • 921
    Re: Toshiba Satellite - Locks up when plugged in
    Good luck man! Always a satisfying feeling when it boots and runs properly straight away
    Just remember to check your polarities and check for continuity between the two sides before you fire it up!
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • Stevenator
      • Oct 2013
      • New Zealand
      #562
      It's ALIVE!!!! bwaa haahaa
      The fix was a 100% success!
      I can't believe such a major TOSHIBA problem was fixed by such a cheap fix. (approx $13 NZ not including labor).
      TOSHIBA should recall all laptops fitted with these NEC Tokin chips and fix this issue once and for all!
      SO here is photo of the finished product as promised.
      I can't claim the soldering work as my own I have a guy who does this sort of thing for me.
      • spleenharvester
        • Mar 2010
        • 921
        Brilliant work matey, well done!
        True they should, but it makes for some cheap buy-fix-resell work for us to do
        • barkeater
          • Oct 2013
          Hey guys, first post.
          I have a Toshiba L305-S5955 and experienced some of the symptoms described here when I upgraded my cpu from the Intel Celeron M 900 single core to a Core 2 Duo T9300 dual core. Problem was driving me crazy. I describe it in detail at Toshiba forum here:
          http://forums.toshiba.com/t5/Compute.../486271#M59550
          Did a fair amount of research and came across this forum which has apparently discovered the root cause and a fix.
          I'm not sure I am going to implement the fix as I have reverted back to the original cpu which does not experience the symptoms. However, if I do decide to reinstall the T9300, I will have to pull the evil thingy and install new caps.
          Thanks again for all your hard work on solving this problem.
          • spleenharvester
            • Mar 2010
            • 921
            There is a good chance it will eventually happen using your Celeron 900, too.
            T9300 is fully compatible with your board btw, I used one myself, great CPU.
            • barkeater
              • Oct 2013
              I agree. Just placed order for my caps and looking forward to the challenge. I am bound and determined to get that T9300 back in there
              • spleenharvester
                • Mar 2010
                • 921
                Guys who have an AMD-socket L300 with no NEC/Tokin which is not POSTing - REPLACE YOUR VCORE CAPS! I've had two boards here for a while which are exactly the same symptoms but have no tokin. Replaced the 4x330uF caps on both in a ditch attempt and it actually worked!
                Might be worth trying on other models with the same too!
                EDIT: One of the boards needs an NB reflow too though so bear that in mind.
                • microfarads
                  • Feb 2012
                  I've found the cheapest replacements for the bad NEC/Tokin caps are the Kemet T520V337M2R5ATE009 --
                  • dycc
                    Vision
                    • Nov 2011
                    • 625
                    • Côte d'Ivoire
                    #569
                    check it and will let you know. get one board with same symptoms
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #570
                      Another success here. Used 4x 330uF tantalums. On this particular model there was also a lonely 220uF tantalum in the middle of the CPU socket, along the usual NEC/TOKIN 0E907 on the bottom. Now the 220uF tantalum cap has 4 new buddies.
                      A working TV? How boring!
                      • fulger06
                        • Nov 2013
                        #571
                        I have Toshiba laptop A300 1GN with cap. 0E907
                        What version you're suggesting is OK:
                        a. 5 caps AVX TAJB227K002RNJ, SMD; 220uF; 2,5V ±10%
                        b. 2 caps AVX TPSD477K006R0045 SMD, 470uF; 6,3V; ±10%
                        c. 2 caps AVX TAJC477K004RNJ SMD, 470uF; 4V; ±10%
                        d. 3 caps AVX TAJC337K006RNJ SMD, 330uF; 6,3V; ±10%
                        Or will propose an equivalent
                        [URL-"http://www.tme.eu/en/katalog/?art=TC-330%2F6.3-SMDD&cleanParameters=1&f_field=artykul&f_order=ASC&page=19%2C20&limit=20#id_category=113245&page=1&s_field=artykul&s_order=ASC"]smd tantalum capacitors [/URL]
                        Thank you for a quick response
                        • fulger06
                          • Nov 2013
                          #572
                          • zinksoft.net
                            • Nov 2013
                            • 17
                            • malaysia
                            #573
                            i also have Toshiba Satellite L300. same problem, restart like hell. Found temporary solution before cap replacement by myself. work for 8 month until now already order a cap replacement for worst case scenario. i create a bat file you can download it unzip and right click the file OneStepRestartSolution.bat and run as administrator .
                            Create a system restore point before continue, in-case you not happy with it.
                            This temporary solved the restart problem and caused cpu temperature increase a bit.
                            No more energry saving, because CPU is in 100% performance.
                            One step registry edit and disabled few thing a temporary solution before cap replacement.
                            DoIt at your own risk.
                            If still having restart problem,
                            goto control panel, power options select High performance and apply this fix again.
                            click Change plan settings, click change advanced power settings,
                            look for Processor power management, at the Process idle disable select Disable idle.
                            Goto BIOS set Always Low. if restart at boot. and start the notebook with a windows7or8 installation USB.
                            press F12, select USB then select repair then select continue booting to windows.
                            • murphyai
                              murphyai
                              • Nov 2013
                              • 26
                              • ireland
                              #574
                              acer aspire 6920g - replaced oe907 with 4 smd 470uf 2.5v capacitors but no luck
                              Hi guys,
                              I've been following this thread for a while.
                              My acer aspire 6920g kept restarting and i researched and found this forum by pure chance.
                              most people thought it was the second processor.
                              anyway, i ordered 4 tantalum smd 470uf 2.5v capacitors as a replacement for the oe907 chip.
                              I used a soldering gun to remove the oe907 chip eventually after 3 hours.aluminium plate down below it was the hardest to remove.
                              I replaced it with the 4 chips.
                              put the laptop back together(which was also tricky with the wiring) and put the power adapter back into it to test.
                              Power comes on and when i hit the power switch the fan starts but that is it.
                              no bios screen on the monitor and keyboard is not functioning now.
                              i assume it's the chips.
                              am i correct in thinking that 4 x 470uf is too much as a replacement for a oe907 as it is 900uf and 4 chips is 1880????
                              [B]
                              help???????
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #575
                                In some applications, the NEC/TOKIN capacitor is used as a feed through capacitor.
                                Current from the Vcore regulator flows into one of the outer + strips and out the other end to the CPU.
                                Check for continuity between where the two outer + strips were soldered to the PCB.
                                Or maybe other damage was caused by too much heating. Its best to rip the capacitor off the PCB as is described earlier in this thread.
                                • dj_ricoh
                                  • 2073
                                  • uk
                                  #576
                                  Re: acer aspire 6920g - replaced oe907 with 4 smd 470uf 2.5v capacitors but no luck
                                  Originally posted by murphyai
                                  Hi guys,
                                  [B]
                                  help???????
                                  hot air near cpu socket =
                                  you rip of the tokin capacitor with a blade .. uff
                                  try to consider on reballing the cpu socket
                                  • murphyai
                                    murphyai
                                    • Nov 2013
                                    • 26
                                    • ireland
                                    #577
                                    i never used a blade at all.
                                    i used a gun soldering iron which is slight hotter that soldering iron
                                    i didn't damage any of the area at all.
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #578
                                      Have you done the test I mentioned earlier?
                                      • murphyai
                                        murphyai
                                        • Nov 2013
                                        • 26
                                        • ireland
                                        #579
                                        it wasn't possible to rip the capacitor off the board and to be honest you will damage a board in most cases doing that.
                                        so i melted it off the board with a soldering gun and then the aluminium plate underneath as well.
                                        i think i haven't soldered the capacitors on correctly.
                                        i will desolder them later and only add 2 x 470uf 2.5 to the board as that is 940
                                        i also received a how to guide from the people who supplied me with the capacitors which i will post now for other users here.
                                        i will let you know later on how the soldering went.
                                        i only have a multimeter as well
                                        • tomodachi
                                          • Apr 2012
                                          • 612
                                          • Turkey
                                          #580
                                          dHelp me !
                                          a friend of mine brought me an A300 with power on but no video problem, before I start replacing Nec/Tokin I noticed a tiny capacitor was burnt near to LVDS socket. Since it has no location code I can't tell what it is but it is a capacitor on 3.3V line.
                                          For every case I replaced nec / tokin to see whats going to happen but no change.
                                          Now I need schematic for this motherboard, if anyone can share I will be very thankful.
                                          (Toshiba A300-1MO)
                                          ps : notebook is consuming 0.35A when powered on.
                                          [/IMG]
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
