Hi. I have MSI GL72 6QD with motherboard MS-16J61. The laptop starts up without an image on the screen on the service power supply show 1.3A-1.45A. The motherboard didn't have water damage. Programmed Bios and EC, when I measured the coils, I noticed no voltage on two of the four (PL6 and PL7) next to the CPU. I have no idea what the fault could be, maybe someone will help?
					MSI GL72 6QD MS-16J61 No image on screen
 Re: MSI GL72 6QD MS-16J61 No image on screen
 POSTing or not?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
 First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
 I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
 Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
 Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...09-11-2025, 10:28 AM
			by ArchimedesSubject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
 Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
 Fans are spinning. Blindly could install windows11 and got the device manager...
			by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
 It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM
			by speedtime07hi everyone ,
 There is an image on the external computer screen ,
 flexi cable test ok - screen test ok -
 What alternative should I look for?
 thank you for your support​
			by smic717394Hi,
- Loading...
