Hi. I have MSI GL72 6QD with motherboard MS-16J61. The laptop starts up without an image on the screen on the service power supply show 1.3A-1.45A. The motherboard didn't have water damage. Programmed Bios and EC, when I measured the coils, I noticed no voltage on two of the four (PL6 and PL7) next to the CPU. I have no idea what the fault could be, maybe someone will help?
MSI GL72 6QD MS-16J61 No image on screen
Re: MSI GL72 6QD MS-16J61 No image on screen
POSTing or not?OpenBoardView β https://github.com/OpenBoardView/OpenBoardView
by ArchimedesSubject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
Fans are spinning. Blindly could install windows11 and got the device manager... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by speedtime07hi everyone ,
There is an image on the external computer screen ,
flexi cable test ok - screen test ok -
What alternative should I look for?
thank you for your supportβ -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by plyanthonyComputer in question : Razer Blade 15 2020 Base Model
Model# RZ09-03286E22
BIOS CHIP: WINBOND W25Q128BV
What I'm trying to accomplish:
I want the computer to properly boot with an external display with the attached display disconnected from the motherboard. I have a CH341A programmer and full capability of modifying the BIOS easily. I Have tried various setting changes to no Avail.
What I've tried thus far: Too much to note and I really dont remember everything I changed but here it goes.
W/Stock BIOS - 1.06:
Disconnect the... - Loading...
