Where to Get Programmed BIOS
  • Zentech
    • Feb 2021
    • 94
    • Usa
    I have a laptop and I want to replace the BIOS chip. This is for an HP Pavilion G6 laptop. I know where to get BIOS chip; however, these are not programmed already. So my question is: Is there any place where to get BIOS chip already programmed?
  • Scotchmist
    • Apr 2019
    • 60
    Re: Where to Get Programmed BIOS
    Hi, you could buy a cheap programmer and clip to reprogram your current bios or new chip. It's pretty easy to do
    https://www.amazon.co.uk/KeeYees-SOI...7SNTL5V6&psc=1
    • Scotchmist
      • Apr 2019
      • 60
      You could buy a programmed chip on eBay example linked
      https://www.ebay.co.uk/itm/172530544053
      • Stevedb
        Stevedb
        • Feb 2018
        • 624
        • Belgium
        Do not use clip that gives bad results
        • Scotchmist
          • Apr 2019
          • 60
          I use a clip when removed from the motherboard, better than soldering onto a board over and over.
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • BMCappelletti
            Asus Chromebox CN62 - wrong chip put on BIOS reader
            by BMCappelletti
            Long story short:
            - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
            - gave the computer to his son a couple years later
            - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
            - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
            (seems like the story was not that short)
            He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
            01-08-2025, 07:27 PM
          • hotcrossedbuns999
            M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
            by hotcrossedbuns999
            My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
            1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
            2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
            3. I could only locate two chips that look like bios chips. Could someone verify this
            01-03-2025, 12:32 PM
          • capoplays
            Help with BIOS update on Dell G15 5515 after chip replacement
            by capoplays
            Hey everyone,
            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
            When I check the BIOS using the F12 menu Flash...
            10-24-2025, 06:53 AM
          • inck243
            Acer e15-e5-576g-5762 bricked. Bios chip won't interface in AsProgrammer.
            by inck243
            Thanks for any help. The board version is DAZAARMB6E0 REV: E. The bios chip is winbond 25Q64JVSIQ1736. W25Q64JV is not available in AsProgrammer -- only BV CV FV or FW_1.8c. The chip won't interface with asProgrammer and a CH341A. When I have this chip on the board, the laptop will not post but when I plug it in to power, the blue LED lights up, also the orange when the battery is connected. When I push the power on button, keyboard backlight turns on and the fan starts briefely then turns off. But I can't do anything to program this bios chip so I bought another one.
            The BIOS...
            07-25-2024, 09:17 AM
