A1706 no image after screen remplacement
  • ledevgeek
    • Mar 2021
    • France
    hello everyone i would like some help i have A1706 EMC 3163 laptop i have had broken screen but was working i have replaced the screen and i lost the image when i put back the old screen no image the laptop turn on but nothing if you can guide me or give help thank you
  • mon2
    • 14661
    Re: A1706 no image after screen remplacement
    hi.
    1) Power down and check each cable from the display to the logic board. Confirm that the mating connectors are seated properly.
    While you are in there, please note and post the logic board number.
    It should be 820-xxxx format and will be etched onto the circuit board somewhere.
    2) Power on - do you hear the boot chime? You can do the PRAM reset to hear the chime.
    3) Allow for the system to boot and then apply a flashlight from the front side of the display at various angles. Can you see the desktop / login icons ?
    If you can see the graphics, then the backlight power supply is not powering the backlight of the display.
    First confirm the above and post your results.
    • ledevgeek
      • Mar 2021
      • France
      hello even with pram no chime on start up , with the flashlight i can not see any login or apple logo black screen i test my port with usb c tester i have 19v and amps is good so i dont now what is the issue thanl you the board is 820-00239
      • mon2
        • 14661
        Suggest to download the schematic and boardview files for this 820-00239 chassis and then inspect each power rail to confirm they are operational.
        https://www.badcaps.net/forum/showth...ight=820-00239
        You can try to remove the display and work only with the logic board and see if there is a chime or fan spin.
        Is the external adapter an official Apple power supply? Is the power adapter powerful enough to support this logic board? Should be 65W or higher I would think.
        The USB Type C negotiating @ 20V is a good sign. Please confirm this. This implies that the USB Type C controllers CD3215 are working properly. This is a good sign.
        See here:
        https://logi.wiki/index.php/CD3215_Bootup_Sequence
        The boot order of operation is the number inside the circle.
        • ledevgeek
          • Mar 2021
          • France
          so i found i first problem when i plug the trackpad the machine doesn't turn on
          • ACS-Repair
            • Feb 2021
            • 204
            Very unusual for this to happen if you took proper care on the replacement. There are voltages present at the screen connector when the power is off. Shorting one of these to ground would damage the supply line. Do you remember disconnecting the battery before pulling or re-inserting the screen cable?
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • dicky96
              HP Elitebook Screen blank - backlights but no image
              by dicky96
              Hi guys
              I'm trying to fix this laptop screen
              Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
              OK so I have the original screen which works but has lines across the bottom quarter of the screen
              I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
              04-28-2021, 07:30 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • speedtime07
              i life zed air cx5 no image on screen
              by speedtime07
              hi everyone ,
              There is an image on the external computer screen ,
              flexi cable test ok - screen test ok -
              What alternative should I look for?
              thank you for your support​
              04-10-2025, 06:24 AM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
