MacBook Pro A1398 - 820-3787-A
  • uas66
    • Oct 2016
    • Netherlands
    Hi all, my keyboard lighting stopped working. I opened the casing to clean the fans, and after that the keyboard lighting stopped working. I did not unscrew something. I see the bars going up and down when pressing on the keyboard lighting keys. Already did SMC, PRAM reset.
    Did I maybe short something on the motherboard?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: MacBook Pro A1398 - 820-3787-A
    Reseat keyboard backlight connector.
    • uas66
      • Oct 2016
      • Netherlands
      Thanks, I already did that. I checked R7723 & R774 and they measure both 10ohm. All pins on J4915 are connected.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Backlight connector could be faulty. Do you have a microscope to see if its bent or ripped? If it is, you will have to replace the backlight film (easy fix but will require you removing the logic board again.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • uas66
          • Oct 2016
          • Netherlands
          Found the problem. R7783 should be 0 ohm but was about 10k ohm. Replaced with a new one and backlight is working again.
          Does someone know how it is possible that the ressistor go bad?
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            Most likely the Resistor may have came off the board partially etc. I have seen an instance where a Resistor was not fully seated and the Audio was out on one of our Boards. We seated the Resistor and solved the issue. I would assume this was the cause, you could have most likely bumped into that Resistor and caused it to lift.
            sigpic
            • piernov
              • Jan 2016
              • 4439
              • France
              Connector manipulated while there was still power inside the board
              • tyler_jones8209
                2021 M1 MacBook Pro (A2442/820-02098-A) Stopped Charging on All Ports
                by tyler_jones8209
                So my friends A2442 MacBook Pro stopped charging one day and hasn’t worked since. It wasn’t like an immediate shut off, like it worked until the battery died but now she can’t charge it so idk what to do with it.
                I don’t have an ammeter (yet it’s coming soon) so idk if it’s doing anything funky with current or voltage but I know it doesn’t charge on ANY of the ports.
                I took it down to the motherboard hoping to see an obviously bad component but everything looks good.
                I don’t have much experience with laptops, only consoles and controllers...
                Yesterday, 04:54 PM
                Apple MacBook Pro 15'' A1398 051-00330 820-00138 Schematic & Board View
                Apple MacBook Pro 15'' A1398 X435 051-00330 820-00138 Schematic & Board View
                A1398 main board resistance measurements (user submitted no further details)...
                10-01-2024, 06:58 AM
              • pippo_one
                Macbook a1398 emc2910 820-00426A
                by pippo_one
                Hi everyone, I have a MacBook a1398 emc2910 with an 820-00426A motherboard.
                I have a short on the "PPBUS_G3H" line... I traced it to the "U7310" IC
                FDMF6808N"
                and indeed the IC is shorted between "Vin and VSWH."
                On the motherboard, Vin to ground = open and it's OK.
                VSWH to ground = about 5,50 / 7.50 Ohms.
                With this measured value, can I safely replace this IC or is the CPU compromised?
                Do you have any other suggestions?
                Thanks for any help you can give me.
                07-20-2025, 03:35 AM
              • fisha
                Apple macbook Pro Retina A1398 Battery not charging
                by fisha
                Hallo everyone, my A1398 do not charging the battery and the battery also do not bin recognized. I did all the reset work, SMC reset and all the other reset options but nothing helped. on the SMC at pin 2 (DCIN) there are 20,4V coming in. at pin 16 (BGATE) which goes to the Q7155 Gate there are only 11,43V. at the pin 1,2 and 3 on the Q7155 (Source) there are 12,23V. Cap C7126 is not shorted. As I understand, the gate voltege have to by higher then the source voltege for the gate to clous so the battery can be charging, am I right? can someone help me with this? I guess that manny models are working...
                07-20-2024, 08:39 AM
              • envym
                by envym
                Hi everyone!
                06-27-2025, 08:54 AM
