Hi everyone i need to discrete to Uma hp dv6500
  • arber1232
    • 368
    • Albania
    Hi everyone i need to discrete to Uma hp dv6500 with mb ..DA0AT1MB8F1 ..I search to find for this model but i not find
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Hi everyone i need to discrete to Uma hp dv6500
    Its possible but practically unviable and involves bga work as well. Do you think its worth the time??
    • piernov
      • Jan 2016
      • 4435
      • France
      This board has both a defective dGPU and MCP, no point in wasting time on it.
        by Vesko356
        08-11-2023, 03:27 AM
      • corrize
        Where to find a very small fpc connector 0.3mm between 2 pins ?
        by corrize
        Hello, I search this connector (oxydated).
        It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
        I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
        I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
        Do you know how to find this connector please ? What is the exact name for find it ?
        08-06-2024, 05:25 PM
        Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
        This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
        Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
        07-07-2024, 02:34 PM
      • temyth
        Sentey ATX PSU - ERP650-PS - Trying to find out the right Standby IC
        by temyth
        Greetings! I have this ERP650-PS atx power supply, it is a relatively simple psu, the primary has a driver IC that controls the two main mosfets (two 20n60S5), together with a Classic Standby circuit with a PWM IC (not a FET like the VIper22A) , relatively similar to the SDC606P.
        The whole point is that I got this power supply years ago when I had no knowledge, apparently the PWM IC was burned because someone turned the power supply on with the switch at 110v in a 220v network (classic error). Important detail: the power supply at the time came without the primary capacitors.
        01-07-2024, 04:50 PM
      • PizzaMan
        Macbook Air A2681 logic board, find this part
        by PizzaMan
        I am trying to find this part on the logic board. See pictures below. It might be CR812, not sure. Any help would be appreciated. And where could I find the part?
        05-24-2025, 12:34 PM
