eg50-kb mb 12253-3m not charging battery
  • brumbrum
    • Sep 2016
    • 24
    • Italy
    Acer aspire e1 522 with eg50-kb mb 12253-3m board.
    Laptop works fine without battery (14,4v battery AL12A32, tested several batteries).
    With battery inserted:
    - I got orange light
    - battery % doesn't increase
    - BT+ on connector with battery is 12.60v (too low to charge battery), without battery BT+ is about 5v
    I attached a capture of the schematic with all the voltages measured (in light blue) on charger ic.
    What could be the problem?
    Thank you
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: eg50-kb mb 12253-3m not charging battery
    When you mesure the voltage was the VIN & Battery were connected? The voltage on BQ24727 pin 3/4/9/8/18/16/17 are not perfect
    • brumbrum
      • Sep 2016
      • 24
      • Italy
      yes, all voltages measured with battery + ac adapter
      • brumbrum
        • Sep 2016
        • 24
        • Italy
        I attached a second pic with voltages checked again and indication on pin 11 that was missing.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          ACDET should not be 0. ACN/ACP reading-are u sure?? Both pin should show almost similar voltage.
          • brumbrum
            • Sep 2016
            • 24
            • Italy
            100% sure of those voltages.
            The only strange thing related to the schematic is that if I try to follow the schematic, pin 4 of pu4404 is connected with pin18 of pu4403. Actually on the board it's not like that.
            In the photo attached there are the readings voltages on pc4413.
            • brumbrum
              • Sep 2016
              • 24
              • Italy
              It's also strange that IOUT is 0 volt, but since I have led and laptop knows battery is connected the SIO is working.
              Can someone help me? Or has someone the right value of the resistor to checj them? Thank you
              • Styopa
                • Apr 2018
                • 23
                • Ukraine
                Voltage on 1 and 2 pins BQ24727 should be ALMOST THE SAME.
                Check PG4402
                • brumbrum
                  • Sep 2016
                  • 24
                  • Italy
                  I don't have PG4402 on board and no boardview.
                  I attached a rar with datasheet and schematic (even if it's a bit different form my board, but almost equal), and also a video of behaviour.
                  You can see the right 16v (needed to charge the 14v battery pack) for 1 second and after, there is stable only battery pack voltage (14v), like something cut the 16v needed to charge battery.
                  Connector all pins are ok.
                  2 battery tested, some behaviour.
                  SIO and data lines should be ok, cause if I charger externally the battery, pc can read the right %, but doesn't charge battery.
                  Without battery plugged I got only 5.82v only B+.
                  Since this chip from datasheet can be managed to charge 12v or 14v batteries, what could be the problem?
                  This case is really strange, and this laptop is making me crazy
                  • Styopa
                    • Apr 2018
                    • 23
                    • Ukraine
                    Are the voltage on 1 and 2 pins of BQ24727 is the same? If not, look for why.
                    • brumbrum
                      • Sep 2016
                      • 24
                      • Italy
                      Thanks for tour reply.
                      No, they aren’t as you can see.
                      On pin 1 19 volt, and on pin 2 battery voltage.
                      But I’m not realizing what’s the problem
                      • Styopa
                        • Apr 2018
                        • 23
                        • Ukraine
                        OK. turn on without battery and measure voltage on 1 pin and 2 pin adn write here.
                        • brumbrum
                          • Sep 2016
                          • 24
                          • Italy
                          Ok no problem. Tell me what you need, and I'll do it, and thanks for your help.
                          without battery connected:
                          pin 1 BQ24727 19v
                          pin 2 BQ24727 5.82v
                          • Styopa
                            • Apr 2018
                            • 23
                            • Ukraine
                            pin 2 BQ24727 5.82v - check (replace) resistor between 1 and 2 pin
                            • brumbrum
                              • Sep 2016
                              • 24
                              • Italy
                              The problem is that, if you mean PR4404, I checked it with tester, and it's ok, but maybe the schematic it's a bit different from my board, cause on pin 1 and 2 of pr4404 there is no continuity with pin 1 and 2 of BQ24727.
                              So I checked the resistor in photo on green line close to BQ24727, without id on board, and I' ve reported the continuity to understand the circuit in photo attached
                              • Bowline
                                by Bowline
                                06-11-2025, 10:13 AM
                              • Julian Bailey
                                HP ProBook 445 G8 Battery not charging
                                by Julian Bailey
                                Hi all
                                We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                I have gone around the board with a MM and cant find anything
                                Windows shows the battery fine,...
                                10-11-2024, 10:34 AM
                              • piernov
                                Laptop battery charging circuit
                                by piernov
                                1. Some theory
                                1.1. Introduction
                                Almost every laptop has a charging circuit of some sort, that does a few things:
                                • Manages switching between AC adapter and battery power
                                • Manages battery charging and generates power rail to charge battery
                                There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                                • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                                • Narrow VDC (NVDC)
                                Texas instrument has a nice overview of these technologies with some more details at https:...
                                11-15-2020, 01:31 PM
                              • kodox
                                ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                                by kodox
                                since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                                the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                                what i've done:
                                - flashing...
                                12-29-2024, 02:49 AM
                              • Shinju
                                Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                                by Shinju
                                Hey All!
                                Long time forum member here with a problematic laptop issue!
                                I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                                The laptop would not power on with the new battery installed without the power supply being plugged in.
                                When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                                TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                                10-20-2021, 04:58 PM
